Which motor mount?
Old Aug 4, 2025 | 02:03 PM
adrianpglover's Avatar
adrianpglover
Which motor mount?
In the middle of doing an oil pan gasket and found that both of my motor mounts are currently of the bluetooth variety (they still sit on each other, but the rubber is no longer connected). I'm looking through the available options through RA and realize that I don't know much about the differences here.
The brands that are offered are "DEA / Marmon Ride Control", Anchor, Westar, or Pioneer. There seem to be 2 types - solid rubber and hydraulic. I'm guess the "hydraulic" ones are just a fluid filled rubber mount, meant to dampen vibrations. The prices generally range from $10-15 each.
So to my question: Which brand/type should I go with? I'm guessing these are all foreign made and of relatively low quality, but so will be the ones from the box stores.
Old Aug 4, 2025 | 02:29 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Pretty much. Expect to replace them again in a couple years.
Old Aug 5, 2025 | 06:05 AM
manicmechanic007's Avatar
manicmechanic007
I'd just go with the Anchor ones
That is what Autozone hands me wjhen I get some from them
Yes Chinese, but work fine
Old Aug 5, 2025 | 08:30 PM
JJF20's Avatar
JJF20
Call the dealer, you might still be able to get a set of Motorcraft.
The difference between pioneer, anchor and a set of Motorcraft are night and day.
There are also Solo Motorsports, and a couple other similar I believe if you search around.
https://cpaddict.com/products/302-an...dcjIkQDe0KrV3j
Old Aug 5, 2025 | 11:30 PM
Scndsin's Avatar
Scndsin
Pioneer. Most likely to be USA made.
Old Aug 6, 2025 | 07:25 AM
adrianpglover
I forget which I ordered, but they were hydraulic.
My dealership often doesn't have parts for my '11, so I doubt they'll have old stock for a '93.
Old Aug 6, 2025 | 08:09 AM
manicmechanic007
Old school here, but the old Lincoln MK and Taurus mounts were hydraulic too and the Autozone ones were more $$ than the Ford ones
However, they were lifetime mounts
Hell, damn hard to replace on a Taurus
After 3 sets of lifetime mounts on a SHO, I switched back to Ford mounts for my sanity
Your truck should be fairly easy to replace a mount on, so I would at least "start" with a cheap one
Old Aug 6, 2025 | 11:01 AM
1Butcher's Avatar
1Butcher
Lifetime warranty usually means you will be replacing that part for a lifetime. It has nothing to do with the life of the part. It's just a sales pitch to buy junk. This applies to alternators and starters too. Anything from the automotive industry with a lifetime warranty means junk.
Of course, there are exceptions, not many, but there are.
octaneforce
Jan 3, 2010 12:24 PM
prerunner
4 Cylinder Engines
Feb 11, 2007 10:50 AM
Fluorspar1
May 4, 2003 10:27 PM
buttnuttn8
Apr 16, 2002 09:46 AM
