Tuning for codes?
Old Aug 3, 2025 | 07:20 PM
Nmaykdm's Avatar
Nmaykdm
Tuning for codes?
I’m rebuilding the top end on my 1995 f150 351w 2wd and I’m almost finished with everything. Iv smog deleted my engine so now I’m at the point where I need to make the ECM think that never happened. I purchased a egr delete plug and I was going to buy a TAB and TAD delete plug ins but they are out of stock. So I was next going to plug in some 75 ohm resistors into these plug ins. But now I’m wondering, can I just have all that taken care of by tuning? Is that something I can learn to do myself?
There is a lot of controversy over if the resistors will work or not so with tuning I’d like to get a for sure check engine light fix. Maybe I’ll be able to tune other things for the better? Any advice?
Old Aug 3, 2025 | 10:19 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Leave the TAB,TAD and EGR solenoids plugged into the computer harness. I kept the EGR connected to vacuum so the sensor will move and then you can block the flow with a piece of aluminum can.
Old Aug 3, 2025 | 11:59 PM
Nmaykdm's Avatar
Nmaykdm
i removed the egr tower pipe that went into the upper plenum and into the manifold. So I can’t plug it back it. I have a delete kit I bought that came with a block off plate for the egr and a plug that goes into the harness.
I don’t know what to do with the three solenoids attached the coil bracket. I’d like to delete them without having a check engine light on if possible.
Old Aug 4, 2025 | 06:11 AM
manicmechanic007's Avatar
manicmechanic007
Bad move
We all breathe the same air
Old Aug 4, 2025 | 06:21 AM
Nmaykdm's Avatar
Nmaykdm
Bad move
I installed gt40 heads that do not have the holes in the back
Old Aug 4, 2025 | 07:48 AM
manicmechanic007
There is more than one way to skin a cat
A 78 Monte Carlo or Zephyr had no holes in the heads either
Keep the cats, keep the air supply to them (if you can)
We're all hot rodders at heart
You can do things like run dual cats and no mufflers
You do not need much EGR to hack the mission of no NOx production
Better to leave the EGR completely intact and just change the orifice size
The washers Ford used to send to make the EGR flow rate match the original valve.. you could throw those out and just drill a smaller hole in a slug or a penny
Ford puts the air "all over" making the 3 way cat work, you don't need any of that crap, I agree
Just run an air pump and throw it in at the manifolds, that is sufficient
It's my daily drivers I keep the I/M intact on
If going racing, all bets are off
Old Aug 4, 2025 | 08:36 AM
Scndsin's Avatar
Scndsin
You don't have to have the EGR pipe. Just the sensor plugged in & the vac line to the EGR diaphragm + solenoid.
The ECU needs to see the diaphragm MOVE.
Old Aug 4, 2025 | 09:17 AM
Conanski's Avatar
Conanski
Don't waste your money on those delete plugs they don't work. The TAB & TAD solenoids don't need "foolin" anyway, some cades may be set with them deleted but they are low priority and won't trigger a check engine light. The EGR is different however, there are several codes that can be set and all of them will trigger a check engine, the only 2 ways to prevent that are with a tuner or by connecting the valve and letting it go through the motions. But if you do that the port in the upper intake must be plugged.
Old Aug 4, 2025 | 09:37 AM
1Butcher's Avatar
1Butcher
My 95 F250 has CA emissions/MAF sensor. The EGR is not like the standard EGR that was used on the Federal trucks. There was nothing I could do to delete the EGR without the light coming on.
I have a Tweecer now. Although I agree that you should not tamper with the emissions but if you are destined to do it anyway, plugging it off is not going to do much of anything. Maybe make things worse. From my understanding, with EGR on, the ignition timing is more advanced. This may cause a knock issue. Backing the timing off may fix that, but all the timing would be backed off.....not good.
With a tuner, you can just tell the EEC-IV that you do not have EGR and therefore everything that happens when the EGR is on, will not.
Old Aug 4, 2025 | 06:52 PM
Nmaykdm's Avatar
Nmaykdm
all this being said, I really don’t want that ugly egr tower on the front of my engine. I got a new exhaust put on by a muffler shop about ten years ago and they didn’t re-attach the tube going into the muffler. So my smog system wasn’t running properly to begin with but the truck still ran great and didn’t throw any codes
Old Aug 4, 2025 | 06:57 PM
Nmaykdm's Avatar
Nmaykdm
without the egr pipe, how do I go about keeping the sensor plugged in? It’s mounted to the top of the egr tower? Just unbolt it?
can you draw this for me? I’m not to familiar with what is what.
my understand is that, the egr sensor is on the egr tower. The TAD and TAB solenoids are the ones beside the coil, I don’t know which is which. There is one more solenoid in front of the coil and I don’t know what that is for.
Old Aug 4, 2025 | 07:01 PM
Nmaykdm's Avatar
Nmaykdm
I really like the tuner option honestly but before I ask more about that, I need details about connecting the valve. What valve and which port in the upper intake?
Old Aug 4, 2025 | 07:03 PM
Nmaykdm's Avatar
Nmaykdm
the sensor is on top of the egr pipe. Are saying to take it off? Looks to have three small bolts holding it on
what exactly is the egr diaphragm and which solenoid is the egr solenoid?
Old Aug 4, 2025 | 08:04 PM
Scndsin's Avatar
Scndsin
The diaphragm is inside the saucer shaped housing the sensor screws into.
it has a vac supply nipple you leave connected.
Vac applied by computer, vac makes the diaphragm move up & down actuating sensor.
Computer happy.
Plug the exhaust manifold attachment, plug the intake manifold port
Old Aug 4, 2025 | 08:43 PM
Nmaykdm's Avatar
Nmaykdm
Computer happy.
I think I understand. What you’re saying is, I can plug the manifold hole, put a plate on the upper intake plenum hole and then take the saucer diaphragm off the egr tube then plug it in to the wire and vacuum line and then it’s all it takes to fool the ECM?
The saucer diaphragm is really an eye sore for me and there really is no good way to hide it unless I extend the wire harness wire.
does all this sound like I have a good understanding?
all that being said, do I leave the three solenoids by coil hooked up like normal?
