Spindle nut help
Old Dec 7, 2003 | 04:02 AM
jocruisen's Avatar
jocruisen
Spindle nut help
Hi all, i did a search and could not find anything on this. I have a '95 Bronco, it had the three hole automatic hubs. I changed them over to Superwinch manual hubs.
My question is, when I had removed the auto hubs I was looking forward to repacking the wheel bearings. I bought the socket for the spindle nuts but the spindle did not have a "3 lock Setup like I have seen in other trucks". How do I remove the complete hubs from the spindle, so I can repack or replace the front bearings?
Did Ford change the design in '95-'96 models?
Thanx in advance,
Jocruisen
Old Dec 8, 2003 | 11:10 PM
jocruisen's Avatar
jocruisen
Bump
Old Dec 9, 2003 | 10:45 AM
jim henderson's Avatar
jim henderson
The different models and years require a different special socket in order to remove the lock nut/spindle nut.
Check with a good tool shop to be sure which one you need. You should also get a bright flashlite and take a good look at the nut to get a fair idea what you need. It is not clear from your note what kind of nut is actually there.
Most of the Ford trucks I have read about and mine in particular, require one of those large(maybe 3 inch diameter) sockets with 4 or more metal fingers that are about 1/4 inch wide. Those fingers go into notches in the nuts and on some models thay also depress a lock washer/spring behind the nut.
I vaguley recall on mine there is a wavy waher between the two nuts and there is one nut with a pin on it that goes into a hole on one of the washers. I would need to look at the manual and or tear mine apart to be sure. In any case, you should be able to get things out with the right socket and an impact wrench.
Some trucks can be finicky. My 94 F250 requires 2 different sizes actually brands of socket. Supposedly the front and rear use the same size, but my truck does not work with the same socket on both wheels. I had to buy two different brands of socket even thought they are technically for the same model. They are just enough different that one works on the front, the other works on the back, weird.
Anyway, my guess is you need the right socket with ears on it.
Jim Henderson
Old Dec 9, 2003 | 10:25 PM
jocruisen's Avatar
jocruisen
Thanx alot Jim. I have seen that socket that you are mentioning and think you are probably right. Anyway, once I have the hub out I can see if its that one or not....
Thats wierd that you would need two different sockets on your truck, then again the tool companies would be at of bussiness...
Jo
Old Dec 9, 2003 | 10:31 PM
jocruisen's Avatar
jocruisen
P.S. Another thing is I have been told that if your Autohubs were 3 bolts you need a special kit. I am assuming its the Spindle nut kit.
But when I spoke to Superwinch about a year ago, They told me no. Now I see that on their site it is mentioned about the kit.
I just hope I havent screwwwwd anything up....There is no play or anything wrong with the hubs, but I would like to have it right...
Thanx again,
Jo
camodown
133
Sep 2, 2025 12:31 PM
fordboy97
Mar 3, 2015 08:40 PM
trevorrules
16
Jun 18, 2013 09:18 AM
Kirbys73F100
May 23, 2013 01:06 PM
jman92612
Dec 19, 2004 11:56 AM
