Need help
Old Feb 28, 2015 | 04:46 PM
fordboy97's Avatar
fordboy97
My truck had a loud grinding noise that I found out was the front right inner wheel bearing. I got new bearings/seals and hub/rotor assemblies. Went to install them today and when I pulled the hub/rotor off I realized the spindle was ruined. So I have a few questions. Where can I get a new spindle? Is it a salvage yard only part? How do you remove the spindle from the steering knuckle, or is it one piece? Thanks guys
Edit: forgot to mention the truck is a 1990 f150 2 wheel drive.
Old Feb 28, 2015 | 04:52 PM
timbersteel's Avatar
timbersteel
I believe that you can order a new spindle. I have checked the parts stores in the past for this.
You need a spindle puller. I bought one years ago and it amazed me how easy it made the job. If I had more time, I'd post a pic.
Maybe someone else can post one. You can get one on eBay also.
Old Feb 28, 2015 | 04:55 PM
fordboy97's Avatar
fordboy97
Thanks timbersteel. I'll look into ordering a new one. How is the spindle removed?
Old Feb 28, 2015 | 05:00 PM
wag53's Avatar
wag53
cheapest would be yard, use two hammers to knock ball joints and tie rods loose after you remove nuts on them. Gotta really whack them but doesn't take long. Thats for knuckle haven't replaced spindle only
Last edited by wag53; Feb 28, 2015 at 05:03 PM. Reason: slow to reply, missed other comments
Old Feb 28, 2015 | 05:03 PM
fordboy97's Avatar
fordboy97
Who can I order it from? Just called the local parts store and they can't get it. The local salvage yards prices are generally way to high but I can try.
Old Mar 1, 2015 | 08:14 PM
fordboy97's Avatar
fordboy97
So I thought the spindle and steering knuckle were separate parts on a 2wd but I found out they are the same part. Also my Chilton's book calls the whole thing a spindle. So to replace this I have to remove the ball joints. Any tips on this? I have never replaced ball joints before or removed a spindle but I am mechanically inclined
Old Mar 2, 2015 | 03:42 AM
mdierking's Avatar
mdierking
You can get one from a salvage yard or an axle so can probably get you one or know where to obtain one.
Old Mar 2, 2015 | 06:28 AM
fordboy97's Avatar
fordboy97
I'm gonna try the local salvage yards today and see what I come up with
Old Mar 2, 2015 | 08:05 AM
rla2005's Avatar
rla2005
Car-Part.com--Used Auto Parts Market is your friend.
FWIW...I think the spindle/knuckle part number is E7TZ-3105-A
Old Mar 2, 2015 | 09:30 AM
fordboy97's Avatar
fordboy97
Thanks for that part # I googled it and found one on eBay. If I can't find one locally I will likely get it.
Old Mar 2, 2015 | 05:27 PM
fordboy97's Avatar
fordboy97
I checked locally and haven't had much luck. Its turning out to be a hard to find part!
Old Mar 3, 2015 | 08:40 PM
fordboy97's Avatar
fordboy97
Ok guys good news got my truck back on the road. I found a good steering knuckle/spindle got it for $40. Cleaned it up and pressed in some new Moog ball joints. Got it all back together tonight and it drives great, no more noises. Thanks to all who helped
granny_rocket
Jan 26, 2013 09:44 AM
1994rangerxl4x4
1978 - 1996 Big Bronco
Jul 13, 2012 07:29 AM
ErrorS
Sep 28, 2010 06:39 PM
ted368
Jun 21, 2007 05:18 PM
Kista20
Virginia Chapter
May 11, 2006 11:00 PM
