Leveling Kit + 35s pulling 5th wheel
Old Aug 5, 2025 | 08:54 AM
  #31
WE3ZS's Avatar
WE3ZS
Are we all talking about the same thing here?
There is a BIG difference between a truck squatted down on the overloads due to a fivers pin weight and a truck running around with a “Carolina Squat” especially one of those loaded with an RV.
Old Aug 5, 2025 | 12:54 PM
  #32
Qwkynuf's Avatar
Qwkynuf
Also in this group - somewhere in between those two - is the ones with the bumper pull trailer with 1,000lbs of tongue weight and no weight distribution hitch. Tongue almost dragging on the ground, headlights helping ET to phone home....
Old Aug 5, 2025 | 01:41 PM
  #33
99powerstrokedF250's Avatar
99powerstrokedF250
And they're the ones that are the most dangerous. A fiver, by design, ALSO puts weight on the front axle because the hitch SHOULD be above or just slightly (we're talking an inch) ahead of the rear axle - meaning a leveled truck with properly aligned headlights won't be blinding oncoming traffic. Bumper pulls with no WDH and a LOT of tongue weight naturally UNLOAD the front steer axle and can cause steering issues.
Old Aug 5, 2025 | 01:48 PM
  #34
Superdave71's Avatar
Superdave71
OP has not been back to the conversation since he asked his question. What kind of group are we here, a bunch of hens berating a guy, spouting off of what LOOKS safe, or an “intelligent “ community of people trying to help a member make a decision without knowing any facts? OP already has the truck and the camper, maybe recommend he go across a CAT scale. Ask for his cargo capacity.
Old Aug 5, 2025 | 02:28 PM
  #35
DPelletier's Avatar
DPelletier
Overloaded tow vehicles are a huge problem; OTOH, WDH's are not a panacea as most people think. I don't use or need a WD hitch to tow my ORV 25RDS behind my F350 DRW, 6.7, 4x4, Camper package, 176" WB truck and my typical load with trailer hooked on has within 150lbs on the front axle vs. empty weight....and more than a completely empty 7.3 truck. Truck sits level loaded with the trailer attached.
Cheers,
Dave
Old Aug 5, 2025 | 02:35 PM
  #36
DPelletier's Avatar
DPelletier
Originally Posted by IADiver
The trucks are not built with rake to improve towing. They are built with rake so that when you are loaded, they to not squat below level. Rake has nothing to do with towing ability. Overload springs are to prevent squat, which in turn keeps more weight on the front end. Any time you put weight on the rear, it takes weight off of the front. By keeping the rear up, you get more load on the front.
Squat has no relation to the axle weights; airbags or helper springs will change rake and ride height but don't change the axle weights to any real degree.
Dave
Old Aug 5, 2025 | 05:05 PM
  #37
Midwest87's Avatar
Midwest87
If the trailer is level, or slightly nose down.
And the truck is above level, nose down.
No problem.
Squatting with load, below level, is bad mojo.
-can effect front axle braking
-can effect steerimg
-can effect sway
-will offend everyone with your mal-adjusted headlights.
Its the mark of an amatuer. I wont ever do it again.
Old Aug 5, 2025 | 05:09 PM
  #38
Midwest87's Avatar
Midwest87
Cheers,
Dave
I know of no professionals that use a WDH. Not a single one in my entire career field. Pintle ball hitches on every truck.
Id spring a TT towing truck to sit right without a WDH. Then maybe add a WDH to reduce bounce, and sway. On flat terrain at least. Would have to disconnect the WDH stuff around here, once off the hwy.
Old Aug 5, 2025 | 08:52 PM
  #39
Joe T's Avatar
Joe T
Probably don’t need a wdh on a Super Duty. On the F150 you have to use one because the hitch is mounted on the bumper bolts.
Geometry is a little different.
Old Aug 5, 2025 | 11:24 PM
  #40
kayakingpoodle's Avatar
kayakingpoodle
Originally Posted by willynilly
calm down karen i would impound sqautted trucks as well. send you walking back home. some police agencies are cracking down on this sqautting crap that people think is so cool.
Easy with the name calling, I will take liberty over the tyranny being suggested in this thread. Go ahead and hammer your weapons into plows if you want but don't tell me I have to. I would wager you **** off just as many people as **** you off!
Ever hear of live and let live?
Headlights from an overloaded or squatted truck are a lot easier on the eyes than the led lights on most vehicles.
Old Aug 6, 2025 | 06:00 AM
  #41
99powerstrokedF250
Equipment trailers and Travel Trailer RVs are two different animals and cannot be compared. Equipment trailers have the advantage of being able to adjust the load to get the tongue weight correct.
With an RV you cannot do that - the weight distribution is static, unless you're willing to tear apart the entire inside of the trailer every time you move it. And storage for things like luggage, food, and camping equipment aren't usually in the best places. So for a travel trailer, a WDH is a VERY good idea. It MAY be unnecessary but that can only really be confirmed with a trip to a CAT scale - and for most of them it's needed. Not all, no, I could likely get away without one for our trailer as it has a GVWR of like 8500 lbs and an advertised tongue weight of like 750 lbs, but I would still use a friction sway control even if I DIDN'T hook up the bars.
But to compare equipment trailers and flatbed trailers to an RV is just not possible.
Old Aug 6, 2025 | 06:03 AM
  #42
99powerstrokedF250
This is completely dependent on the truck/trailer combination. Yes there are some that don't need it. There are a LOT that do, and I see them all the time on Fridays during the summer - Super Duties, HD Rams, HD GM trucks, headed north for the weekend with their 30+ foot TT behind them, truck nose-high and trailer nose-low because 'I have an HD truck I don't need a WD hitch.' Watch them hit bumps and the front axles are almost all the way unloaded. Glad I'm always headed south on that day.
Old Aug 6, 2025 | 07:14 AM
  #43
Joe T's Avatar
Joe T
Sure. Lots of variables and if you pull a TT probably not a bad idea to get a wdh at minimum for sway control.
Old Aug 6, 2025 | 07:23 AM
  #44
mtnguy's Avatar
mtnguy
True, geometry is a little different, but not by much.
When you hang weight 2’ behind the rear axle of a truck, the front end will raise. The Super Duties have the advantage of extra weight, plus the rear axle is full floating meant to carry weight.
I choose to use a WDH on my F350 pulling my 26’ travel trailer with 900 lbs of tongue weight. Am I required use 1 according to Ford ?? No. Does it help with the drivability of my truck ?? Definitely. And the sway control provided is another plus.
I venture to say that the front axle weight with 900 lbs on my hitch (without a WDH) and the diesel upfront is probably about the same weight as the front axle of a gasser with no trailer.
Hmmm, now that had me thinking.
Blkdane
Feb 15, 2021 08:55 PM
bigc1301
All Things Towing
30
Oct 11, 2017 06:44 AM
orionife
Feb 12, 2008 03:56 PM
nut1605
Apr 12, 2007 02:24 PM
eckart
Jan 15, 2005 05:36 PM
