Sponsored by: Real Truck
6.2 no start
Old Jul 28, 2025 | 03:13 PM
Born Blue Bob's Avatar
Born Blue Bob
6.2 no start
2014 F250 with a 6.2. Does anybody know there is a common reason that it will not crank? Power to the starter, battery good, relay good. However some messages come up on the dash when attempting to start the truck as well as check engine light.
Bob
Old Jul 28, 2025 | 04:02 PM
Pikachu's Avatar
Pikachu
Bob
What are the messages? Is your gear indicator orange and showing either P or N?
Old Jul 28, 2025 | 06:02 PM
Born Blue Bob
No, the gear display will not light up.
Old Jul 28, 2025 | 06:15 PM
Born Blue Bob
The messages are a variety, and it was also put in neutral and attempted to start as well. Will be replacing the starter tomorrow. I am asking on behalf of my Son-in-law so I don't have the vehicle to review myself.
Bob
Old Jul 28, 2025 | 08:58 PM
Pikachu's Avatar
Pikachu
If the PCM doesn't know that the trans is in either park or neutral, it won't allow the engine to crank. If there isn't any indication of the gear, it could be a bad transmission range sensor. Does he have any way to read codes and see live data?
Old Jul 29, 2025 | 07:04 AM
Born Blue Bob
Yes, he has a reader but it was not showing any codes. I will be going to his place this weekend and will bring my scanner and try it.
Thanks.
Old Jul 29, 2025 | 11:41 AM
Pikachu's Avatar
Pikachu
Thanks.
Ok, also there's a connector that should be clipped to the inboard side of the battery tray that has a single wire in it. It should be a 12 ga brown wire with a green tracer. I know this is the case for 2011 and 2012. The male side of that connector should go directly to the starter solenoid. Verify that it does go to the starter before doing this, but applying +12v to that wire should engage the starter. If it works, the starter is good and further troubleshooting is needed.
jessie56
2009 - 2014 F150
Jan 31, 2022 09:34 AM
mikels
17
Jul 21, 2021 12:08 AM
DENNIS VANSLYKE
1997 - 2003 F150
Jul 24, 2011 09:47 PM
sandmann
Aug 25, 2009 12:16 AM
FearTheDentist
Jul 17, 2006 11:59 PM
