need correct speedometer gears
Old Jul 28, 2025 | 10:32 AM
Goshencars's Avatar
Goshencars
I need to change the speedometer gears in my 50 f2 4 speed crash box. I am installing a newer rear end with a 3.73 ratio to replace my old 4.86. the old driver gear is 20 tooth # 01Y-71 C-20. The driven is DY-85-A8. I am going to run 7:00-16 tires with an OD of 30.6" diameter.What gears do I need and does anyone have a set? Thanks
Old Jul 28, 2025 | 11:13 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Your 4.86, 7x16, and 4 speed would have a 01Y-17285-A 6 tooth gear and 01Y-17271-C 20 tooth gear. The -17285-A was for the 3 speed...
I'm not finding that Ford has a prescribed matching combination listed for 3.73, 7x16, and 4 speed.
Old Jul 28, 2025 | 12:23 PM
Goshencars's Avatar
Goshencars
I also thought of putting an external speed change unit on but while it is apart it would be nice to switch the gears.
Old Jul 29, 2025 | 09:55 AM
Jeeptrix's Avatar
Jeeptrix
If you figure out the correct gear required Chuck's Trucks is the first place to look for it.
Old Jul 29, 2025 | 10:23 AM
Goshencars's Avatar
Goshencars
Jim Carter trucks lists a changer for $160 for GM. Is Ford and GM interchangable on their cables?
Old Jul 30, 2025 | 07:39 AM
Goshencars's Avatar
Goshencars
I found an old thread (2015) that had a similar request. They listed the following gear set. drive gear 8J 17285 and driven gear 01T 17271-A. Will these work to get close and does anyone have them Thanks
Old Jul 30, 2025 | 08:47 AM
bmoran4's Avatar
bmoran4
That combination is for 1956 4 speed with 7x17.5 tires and 3.73. You can use online calculators suc as these to see how close you are getting and if it is to your liking:
https://www.gtsparkplugs.com/SpeedoGearCalc.html
https://moveras.com/Support/Tools/Sp...ear_Calculator
https://www.5speeds.com/calculators/SpeedoCalc.html
Old Jul 30, 2025 | 09:10 AM
Goshencars's Avatar
Goshencars
Thanks for checking for me
DrCharles
May 6, 2025 01:18 PM
64GRAINBODY
Jun 1, 2019 06:08 AM
Truck Guy99
Feb 23, 2014 02:28 PM
andyman7931
May 17, 2009 02:54 PM
ScottJM
Oct 7, 2003 12:42 AM
