Power door lock actuator
Old Jul 27, 2025 | 06:13 PM
ApparentlyIlikeFordtrucks's Avatar
I have a 1986 F250 with power door locks. Both actuators are bad. I got some on Amazon and they have several different tips that can be installed. None of them match the rod that came with the originals. The originals just have a 90 degree bend and snap into the plastic clip on the lock mechanism. The picture is of the wrong style actuator.
I looked up different brands and even tried an older model (1984), and they're still the same wrong tips. Any ideas?
Old Jul 27, 2025 | 07:30 PM
Franklin2's Avatar
Franklin2
Since this place doesn't sell the correct year actuator, you probably can't get them.
https://www.lmctruck.com/door-compon...oor-components
You can't take what they gave you and put it in a vise and bend it to fit?
Old Jul 28, 2025 | 12:46 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by ApparentlyIlikeFordtrucks
Any ideas?
Make the generic aftermarket part work. Either that or try to find some good OEM from the junkyard or a site like eBay.
Old Jul 28, 2025 | 09:58 AM
After a lot of head banging and Google searches, I determined that this is an 'updated design".I suppose that they assume that the plastic clips won't last this long. If you remove the clip, you can slide the new style arm into the latch lever. It's a sloppy. loose fit, but it works. Since everything is Chinese junk, only one worked.
Old Jul 28, 2025 | 04:28 PM
My4Fordtrucks
or you can do what I did and install the Z shaped rod thru the plastic clip and then rivet/ bolt the actuator to the door.
Yes. The one on the Bronco II only lasted a couple years. I replaced the cheap aftermarket part with a used OEM from the junkyard.
Mike Sanders
1947 and Older Ford Trucks
May 17, 2021 04:37 PM
1995F150XLT4x4
Nov 13, 2020 06:29 PM
85MOTORSPORTXLT
Apr 4, 2016 06:19 PM
bryyce62
Oct 9, 2011 07:47 PM
MJB
Bronco II
13
Jan 3, 2004 10:05 AM
