CP4 Disaster Strikes
Old Aug 2, 2025 | 08:10 PM
  #46
Overkill2's Avatar
Overkill2
Originally Posted by wcbcruzer
I think the OP is referring to the warranty on the parts/labor of installing the new CP4, not the original manufacture warranty. If that's they case, they may void it if DPK is installed. However, like any other warranty claim, seems to be dealer dependent.
In terms of the newer CP4 pumps, they have pinned the roller which is actually a huge upgrade. Yes, they can still fail as there is a lot of cam lobe lift inherent to the CP4, but the fact that the lifter is pinned is actually a big deal imo. So it doesn't spin around, which causes definite failure of the pump. Glad Bosch figured this one out.
Regarding additive, pick Hot Shots every diesel (performance dose), or Archoil. Idk much about K100, but Overkill swears by it and I trust him. Additive is NOT snake oil. I'm just going to say it like it is. No need to beat around the bush on this matter as it's not really an opinion at this point. You're basically improving US spec diesel to European specs that the CP4 was designed for. If your pump fails after using good additive in every tank, then that's either wear-and-tear, or just a faulty pump to begin with. At least you did your part.
Appreciate that but I'll never say what I use or what I do is the best.
There's too much to risk, not taking precautions like using additives every tank and/or getting a dpk or a DCR.
From the folks here who have had a failure very early into their trucks life to the guys going out 200k plus with their original CP4, its a roll of the dice that I'm not willing to take.
Then there's the famous 922k mile 17 6.7 that was worked hauling campers with the original CP4 and the religious use of additive along with regular stock fuel filter changes. If that's not a testament to modern fuel additives, then I don't know what is.
And saw the DCR just increased to $2400 for those who will be buying one to replace a CP4. I'll replace my CP4 when it fails... time will tell but I'm ready.
Old Aug 2, 2025 | 08:27 PM
  #47
wcbcruzer's Avatar
wcbcruzer
I may be one of the few, but I believe with an additive and regular fuel filter changes to maintain proper fuel pressure, the CP4 is non-inferior to other injection pumps. Cummins is now using the CP8, which appears to be very similar to the CP4.2.
The reason GM and Ram recalled those pumps was because they didn't know better at the time. The CP4 was new and I think GM didn't even have a primary fuel pump to supply it. These Fords push 55-60 psi of fuel to the CP4. When fuel filters get dirty, the feed pressure goes down. That's why it's important to change them. Now you don't have to be ocd about it, but just don't neglect it. Every 15-20k should do. And make sure there's no water in the tank of course. That applies to any brand.
Old Aug 2, 2025 | 08:35 PM
  #48
wcbcruzer's Avatar
wcbcruzer
I'm in the same boat.. haha. Hopefully not for a long time.
Old Aug 2, 2025 | 08:51 PM
  #49
dougger222's Avatar
dougger222
If you do a google search you'll find examples. I see them from time to time go through Copart and IAA with junk engines due to fuel contamination. It's not very common but it can and does happen.
My buddy has a 2012 F350 6.7 King Ranch with 605K miles that has basically everything still original on it. He bought it from a 1 owner hot shot.
Old Aug 2, 2025 | 10:11 PM
  #50
longhaultransport's Avatar
longhaultransport
2 price increases on the DCR in 2 days.
I was on the fence about a DPK or a DCR.
Not any more.
Old Aug 3, 2025 | 07:33 PM
  #51
Overkill2's Avatar
Overkill2
AGREED
Old Aug 3, 2025 | 07:39 PM
  #52
Overkill2's Avatar
Overkill2
I see anywhere from mid 80s to 90 psi for my primary fuel pressure on my iDash...
Prior to the S&S dpk install, I saw mid 80s and then by the end of the filter set life, high 70s.
Now with the S&S kit, I see high 80s/low 90s (no higher than 92) and at end of filters service life, mid 80s or so... wild that I saw a slight increase in pressure with the S&S kit.
  #53
Overkill2's Avatar
Overkill2
Not any more.
So the DPK then?
Old Aug 3, 2025 | 10:21 PM
  #54
longhaultransport
So the DPK then?
Absolutely, I'll wait until when or if I need a new pump, then decide which is the best value.
Old Aug 4, 2025 | 12:40 PM
  #55
acdii's Avatar
acdii
How do you know the additives are NOT made from Snake oil? OIl is oil when it comes to lube. LOL
Yes a CP4 CAN destroy the engine and Yes due to the gear rotating on the crank. If the pump seizes, it can lock the gear which locks the big gear which locks the crank gear, and Boom, engine broken. The CP4 has to be in really bad condition for that to happen and should have been caught long in advance. This is one reason I like the clear bowl of the SPE.
Old Aug 5, 2025 | 08:43 AM
  #56
jollyrogr's Avatar
jollyrogr
I like the clear bowl of my S&S return filter too. Can see if there's any glitter in there. Eventually I'll install a DCR. I see the price went up, but glad they're going to be making the pumps in the USA.
Old Aug 5, 2025 | 09:50 AM
  #57
Overkill2's Avatar
Overkill2
Wow... did not know that until now.
While I would have bought a DCR built in China, I do not mind spending $400 to buy one built here and with improvements...
I hope never to buy one, but if need be, Made in the USA babee...
Old Aug 5, 2025 | 10:05 AM
  #58
acdii's Avatar
acdii
'MERICA!!
See, Tariffs do work! LOL
I actually found a few places that make 3D filament right here in the good ol USA. Too bad the prices can't compare to Korean filament. It would cost me $80 more to fill my AMS. All we need now is a bit more competitive pricing on consumables.
Old Aug 5, 2025 | 10:06 AM
  #59
Overkill2's Avatar
Overkill2
'MERICA!!
Yep... The goal was to bring manufacturing here. Short term pain, long term gain.
Old Aug 5, 2025 | 10:23 AM
  #60
acdii's Avatar
acdii
Trying to jump that train myself with a small 3D manufacturing start up. Why should people buy cheap keychains all the way from China when they can be made right here in the USA to their designs!
