5th wheel prep package
Old Jul 23, 2025 | 04:51 PM
Frank79's Avatar
Frank79
When purchasing a truck with a fifth wheel prep package, is there anything else that I would need to buy to make this operational to use as a gooseneck?
Old Jul 23, 2025 | 05:10 PM
longhaultransport's Avatar
longhaultransport
The gooseneck ball. I like the
B&W version. B&W version.
Old Jul 23, 2025 | 05:12 PM
1olddogtwo's Avatar
1olddogtwo
Ball and safety hooks are needed.
Old Jul 23, 2025 | 06:05 PM
ShotgunZ71's Avatar
ShotgunZ71
The B&W OEM kit is a bit cleaner, but also a little more money. Depends on how often you plan to take the ball out. I got the GM/Ford kit by Curt and didn't think about the B&W until after the fact. I don't remove the ball and anchors often, so either is fine for my use.
Old Jul 23, 2025 | 06:22 PM
Tsax6010's Avatar
Tsax6010
B&W version.
This is what I use too. Highest quality out there and the only option still made in the US. Be careful where you buy from as there are a ton of china knockoffs doing their best to trick you into thinking it is a B&W. Stick to authorized retailers.
Old Jul 23, 2025 | 06:32 PM
Frank79's Avatar
Frank79
i just installed a b&w gooseneck a few months ago in my 2020. I have the option to flip the ball over when not in use.
I wonder if that ball is compatible with fords factory setup?
If so, all i would need are 2 pucks.
Old Jul 23, 2025 | 06:53 PM
ShotgunZ71's Avatar
ShotgunZ71
No, it's not compatible. The turnover ball has a square pocket it sits in, whereas the OEM is round.
Yeah, it stinks that you can't use it for a new truck with OEM setup.
Old Jul 23, 2025 | 07:19 PM
1olddogtwo's Avatar
1olddogtwo
I just ordered the factory ball kit, comes in a nice box that fits in the console comfortably, you would almost think they're designed for each other.
Old Jul 23, 2025 | 07:22 PM
Frank79's Avatar
Frank79
that stinks! $1400 down the drain 🤦‍♂️🤦‍♂️🤦‍♂️
I’m guessing there is a lever on the driver wheel well to lock the ball in?
Old Jul 23, 2025 | 08:00 PM
longhaultransport
The B&W round shaft OEM style version I linked?
No, the handle on the ball is what locks it in place.
Pretty easy to see how it works in the Amazon pictures.
Old Jul 23, 2025 | 08:10 PM
ShotgunZ71's Avatar
ShotgunZ71
Yep. What LHT said. Just a little turn and flip tap on the ball.
You can get the B&W for OEM prep. They have that nice fold down handle to lock the ball in place.
Old Jul 23, 2025 | 08:14 PM
1olddogtwo's Avatar
1olddogtwo
Wobbies have gotten pricey
https://www.ford.com/product/hitch-k...wr-p2852522034
Old Jul 23, 2025 | 08:16 PM
1olddogtwo's Avatar
1olddogtwo
Wow, they have gotten pricey
Old Jul 23, 2025 | 08:21 PM
ShotgunZ71's Avatar
ShotgunZ71
https://www.bwtrailerhitches.com/pro...fety-chain-kit
https://www.curtmfg.com/part/60639
Old Jul 23, 2025 | 08:29 PM
Frank79's Avatar
Frank79
Sorry. I just looked closer at the Amazon link that you posted. It looks like that ball has a little ball detent that keeps the ball from popping out.
On the one I had installed in my truck there’s a little lever under the driver wheel well that I have to pull out and push to the side to remove the pen that goes through the ball shaft.
