Fuel filter light issue
Old Jul 22, 2025 | 02:30 PM
LowcountryF150's Avatar
LowcountryF150
I have a 97 7.3 F Super Duty and recently had the fuel filter light come on. I let it ride like that for 2 days which ended up causing my engine to die while driving. No start after that. Got it towed back to my house, changed the fuel filter, bled the air out of the lines and after a bit of cranking she was back alive. Drove fine for a day. Now I’m getting the fuel filter light again coming on and off. Feels like the engine is almost not getting enough fuel, or like it’s misfiring under load. I’ve bled the lines again and used the valve to bleed air as well, but seems like it’s already all out. Engine feels as if it wants to give out after warming up and I’m going 45+ but it hasn’t so far. Has been running like this for the past 4 days. Does anyone know what this could be? Injectors? Fuel pump? Fuel pump is a year old replaced with factory motorcraft.
Old Jul 22, 2025 | 02:47 PM
knottyrope's Avatar
knottyrope
Filter lilght means vacuum
Injectors can pull fuel like a mini pump
Do a pump pressure and flow test, yours might be week or their could be stuff in tank or valve blocking inlet flow
20 cranking
45 minimum running at any RPM
and do this each filter change
https://www.ford-trucks.com/forums/1...-to-clean.html
Old Jul 23, 2025 | 07:37 AM
LowcountryF150
Ok, I’ll try that after work today. Thanks
gage-black
Nov 6, 2022 12:55 PM
jacobknowles123
Nov 12, 2021 04:41 AM
PrinceVegito
Apr 11, 2021 10:37 PM
r_carhill
Sep 10, 2013 07:55 PM
ejstith
Jun 28, 2005 08:12 AM
