Leak
Old Jul 20, 2025 | 12:48 AM
scottz99's Avatar
scottz99
Veteran: Navy
Leak
Last week, my truck was out overnight in the rain. The next day I noticed a few drops of water coming out the drivers A-pillar hand hold. I suspect there is a leak at the windshield (it has been replaced once) or one of the clearance lights. Anyone experienced this?
I’m thinking the first and easiest step would be to reseal the clearance lights and see if that helps but I’m not sure how to go about it. Can I take the clearance lights off from the outside, without pulling the headliner? What’s the best way to reseal them? I assume they have gaskets or I could use silicon? Will silicon even stick since this truck has been ceramic coated?
Thanks
Old Jul 20, 2025 | 07:41 AM
Lou Braun's Avatar
Lou Braun
A leak from the A-pillar could be from the windshield, roof body seam or possibly a clearance light. In any case, you need to find just what is leaking first. This will require some trim disassembly and a helper with a water hose (that is what I did). Others have used compressed air form inside and soap solution applied on the possible leak locations on the outside of the truck. If you do not want to do this yourself, a good glass shop should be able to find this leak since they do this type of work often.
Once you find the leak, it should be a relatively easy repair. If using a sealer, a professional grade of urethane sealant should work well.
Old Jul 20, 2025 | 08:24 PM
HarveyTruck's Avatar
HarveyTruck
I’m assuming you don’t have a moonroof since you didn’t mention it. The two A pillar leaks I’ve had were:
moonroof drain tube completely falling off and water drained from moonroof drain directly into the A pillar. Grab handle was first least resistance place to leak. Very easy leak to replicate and find. I suppose a cab light could do similar but it’s probably the corner one or you’d see it on the headliner.
roof channel seam very small crack in the sealer at the corner of the windshield and trim piece. The leak manifested itself much lower coming out the holes between the pinch welds into the dash trim and over to the E-brake pedal. Couldn’t get that one to replicate, only occurred after longer rain. Finally saw the tiny crack, sealed it with windshield sealer and it’s been good.
Drop the corner of your headliner and take a look for evidence. Very easy to do. I think if it’s coming out the grab handle you’ve got a direct dump into the headliner and interior trim.
Old Jul 20, 2025 | 09:17 PM
turfengineer's Avatar
turfengineer
Same here. My dad’s F150 had a small hole in the roof seam on the drivers side. A little sealant fixed the issue for him.
Old Jul 20, 2025 | 10:03 PM
scottz99's Avatar
scottz99
Veteran: Navy
Thanks; I'll start looking into it. No moonroof; for exactly this reason; last truck had one that leaked.
Old Jul 21, 2025 | 10:47 PM
scottz99's Avatar
scottz99
Veteran: Navy
Looks like it is the windshield. Used a plant waterer with a spout to strategically pour water. I can feel it under the front edge of the headliner when water is poured on the top edge of the windshield. I'll have the glass shop that replaced the windshield take a look at it.
Thanks for the assist.
Old Jul 24, 2025 | 01:35 PM
Ford Motor Company's Avatar
Ford Motor Company
Official Ford Pro Rep
Thanks
Hi there. We'd like to look into the issues you're experiencing with your windshield. Feel free to send us a DM with your vehicle's VIN and mileage.
Old Jul 24, 2025 | 03:49 PM
406f150's Avatar
406f150
For anyone else that has this issue mine was leaking around the cab lights and running out the handle on the A pillar and out the upfitter switches. Seals are foam with peel and stick adhesive on the bottom and permanently attached to the cab light. Have to replace the whole light, and the o-rings under the screw heads are only available with new screws (sold separately). Updated style lights have thicker foam and seal much better than what my 2017 had stock. 2020-2022 trucks use clear light housings if interested in that for the 2017-2019 replacements.
Old Jul 25, 2025 | 02:21 PM
scottz99's Avatar
scottz99
Veteran: Navy
I took it to the glass shop (the same one that replaced the windshield three years ago). It took them about 10 seconds to identify the problem. Pushing out on the top, left side of the windshield revealed that it was no longer bonded; you could feel it move. They said that have seen this on several Ford Super Duties. New windshield on order (can't remove the old one without breaking it) and will be replaced next week.
Old Jul 25, 2025 | 06:53 PM
HarveyTruck
Glad you figured it out. What they should have said was we want to sell you a new windshield or we’d have to try not to break yours. When tracing my leak my glass guy (who I’ve used several times) told me he’d could reseal it and try not to break it but couldn’t guarantee it wouldn’t due to age. Mine is 7 years old. They can be resealed but also it’s worth whatever it takes to resolve the issue.
Old Jul 25, 2025 | 07:50 PM
scottz99's Avatar
scottz99
Veteran: Navy
They are replacing the windshield at no charge; in spite of being three years old. Otherwise, it would only have been a matter of time before it got hit by a rock.
Old Jul 25, 2025 | 10:17 PM
HarveyTruck
If they’re covering it then heck yeah. Glad you got it resolved. I know the relief when you get the next rain and it’s dry!
Tony2002excursion
6.7L Power Stroke Diesel
Sep 1, 2023 03:56 PM
Great Danes
Mar 18, 2022 01:43 PM
ever22
Jul 31, 2020 09:22 PM
Concept81
1997 - 2003 F150
Nov 6, 2010 12:35 PM
