F250
Old Aug 26, 2023 | 03:51 PM
Tony2002excursion's Avatar
Tony2002excursion
F250
111111111111111
Old Aug 27, 2023 | 06:55 AM
clippity-clop's Avatar
clippity-clop
There is a recall I think on the clearance lights but they will only fix them "as" they leak. I've had 2 fixed so far. I bet it could be them. Water moves unpredictably. Might call your ford dealer and ask them if there is a recall. I think they can tell which ones are leaking. Good luck.
Old Aug 27, 2023 | 09:29 AM
Tony2002excursion
Old Aug 27, 2023 | 11:55 AM
speakerfritz's Avatar
speakerfritz
Get a buddy to wet down windshield with out wetting roof…see if that duplicates it
then try to wet roof only and see if that duplicates it
There are other areas but not localized to the corner your pointing to.
see if the pax side floor behind driver is wet…there is a rear cab vent leak problem.
Old Aug 27, 2023 | 12:31 PM
FishOnOne's Avatar
FishOnOne
Old Aug 27, 2023 | 01:34 PM
Tony2002excursion
Old Aug 28, 2023 | 12:23 PM
Overkill2's Avatar
Overkill2
It could be a cab light on that side then possibly...
Old Sep 1, 2023 | 03:56 PM
Sport45's Avatar
Sport45
Originally Posted by Tony2002excursion
Its only on the passanger floor matt doesnt get anywhere else . The floor under the drivers matt never get wet its only directly on the drivers matt
Are you saying the passenger side gets wet too?
Garbageman 134
Jan 1, 2023 11:51 AM
Mbucksath
Dec 14, 2022 10:33 AM
fleastang
May 8, 2017 07:02 AM
Wvstream71
Aug 18, 2016 06:02 AM
1979camperspecial
Jan 15, 2010 10:31 AM
