Fuel pump not working?
Old Jul 19, 2025 | 04:22 PM
Mountain_anderson's Avatar
Mountain_anderson
Hi all
I just finished replacing the thermostat on my 86 f150 5.0 4x4. It has a single tank. Afterwards, I went to start it and nothing happened. I noticed no sound going off from the fuel pump. I pulled the line and nothing came out when I turned the key on. I replaced the fuel pump relay and nothing still, no click from the both the old and new relay. I tried jumping the intertia switch with a peice of wire and still nothing. What else could this issue be?
Old Jul 19, 2025 | 05:48 PM
FuzzFace2's Avatar
FuzzFace2
For testing bypass the pump relay and check for power back at the pump.
No power you will need to back trace from pump to relay why.
If you got power try banging on the bottom of the tank and see if the pump will start and if not bad pump.
Dave ----
Old Jul 19, 2025 | 09:18 PM
Franklin2's Avatar
Franklin2
Put everything back together and go back and beat on the bottom of the tank with a piece of wood while someone tries to start it. It will probably go. This is a important trick to know if you are out stranded somewhere with a bad pump.
Old Jul 20, 2025 | 04:48 PM
Mountain_anderson
Hi all
I actually got it working. It was that small ground cable from the negative terminal on the battery. I had it grounded in the different spot. Grounded on the battery now but it once again won't start. I have fuel coming at the injectors and spark. It was running fine before hand
Old Jul 20, 2025 | 06:45 PM
Franklin2's Avatar
Franklin2
I can tell you what will easily happen to these old fuel injected trucks. If you have been messing around with it, cranking and cranking, it is very easy to foul the plugs. When they are fouled they will not fire. So pull a plug or two, see if they are wet with fuel. If they are, pull them all out, dry them off with brake cleaner and a air hose,, and then put them back in and try again.
Old Jul 20, 2025 | 09:29 PM
Denzil B's Avatar
Denzil B
Originally Posted by Mountain_anderson
Hi all
The click is the relay. No click, no power at relay. Check and clean the ground for the relay.
ctflareside
Mar 19, 2021 06:02 PM
kameronth
Modular V10 (6.8l)
Jan 4, 2011 09:55 PM
jasonjason
Feb 21, 2008 04:27 PM
mike_23us
1983 - 2012 Ranger & B-Series
Nov 26, 2005 11:13 PM
jimlahey
Aerostar
Oct 9, 2005 01:53 PM
