coupler rating?
Old Jul 19, 2025 | 11:48 AM
nychan's Avatar
nychan
coupler rating?
Got a 14k trailer and noticed the coupler is rated for 12.5k. Is this the wrong coupler? TIA
Old Jul 19, 2025 | 12:42 PM
OBS460's Avatar
OBS460
I'd swap it out with something rated for as much or more than the trailer rating if possible. Your trailer is essentially a 12,500lb rated trailer at this point .
Old Jul 19, 2025 | 05:18 PM
Eman85's Avatar
Eman85
What is your hitch ball, adapter and hitch rated for?
Old Jul 19, 2025 | 06:03 PM
nychan's Avatar
nychan
14k, 14k, + 15k
Old Jul 19, 2025 | 06:35 PM
nychan's Avatar
nychan
I bought this new from a dealer and they chk'd it before I left to make sure it was hitched correctly.
It's not the $100 coupler, it's the principle! Am I out of line expecting dealer or mfr to make it right?
Old Jul 19, 2025 | 07:38 PM
OBS460's Avatar
OBS460
Definitely not out of line. They shouldn't be able to legally rate it for 14k if the major components are not even rated for that. It might as well have 6k axles on it if the coupler is only rated for 12,500lbs.
Old Jul 20, 2025 | 12:43 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I agree, dealer or manufacturer should fix it.
Old Jul 20, 2025 | 08:59 AM
ATC_F350's Avatar
ATC_F350
I've talked to DOT and he emphasized that every component has to be rated for the load, the lightest rated component limits the whole load. You do not have a 14k trailer, you have a 12.5k trailer. Have the dealer fix it.
Old Jul 21, 2025 | 07:01 AM
arse_sidewards's Avatar
arse_sidewards
There's a reason that topics like these are dominated by people talking about rules and legality or speculating about engineering instead of anecdotal stories about people breaking 5k couplers and ***** and whatnot hauling 6k. Yeah you can probably have the dealer "fix" it if you raise the issue but I personally wouldn't lose any sleep over it.
Old Jul 21, 2025 | 01:01 PM
meborder's Avatar
meborder
The coupler rating should match or exceed the GVWR of the trailer. This is kind of a swing and a miss on the part of the manufacturer.
that said ….
that looks like a bulldog coupler …. You ain’t gonna break it.
Old Jul 21, 2025 | 01:25 PM
99powerstrokedF250's Avatar
99powerstrokedF250
that said ….
Yeah I would agree with everything here. It SHOULD match or exceed the GVWR of the trailer, and it being marked at 12,500 means the trailer SHOULD be rated 12,500. BUT that type of coupler is pretty darn bulletproof, and I've seen 10k car haulers with that coupler loaded up so heavy the tires were rubbing the fenders on every bump, and the coupler didn't even blink.
Old Jul 21, 2025 | 01:50 PM
nychan's Avatar
nychan
Emailed the dealer...
At 1st they said it was a 25k coupler!
I replied with the link to the coupler and they replied "IM SORRY, I HAD TO LOOK AGAIN IT SAYS 12,500 TOWING CAPACITY BECAUSE YOU HAVE TO THE DEDUCT THE TRAILER WEIGHT "
Title shows 3k trailer weight.
14k-3k=12.5k.
Are they correct?
Old Jul 21, 2025 | 03:26 PM
SpencerPJ's Avatar
SpencerPJ
At least you have in writing should something fail.
Old Jul 21, 2025 | 03:58 PM
ATC_F350's Avatar
ATC_F350
14k-3k=12.5k.
Are they correct?
No. The trailer weight is behind the coupler and pulled by that coupler, that weight doesn't disappear.
Old Jul 21, 2025 | 04:15 PM
arse_sidewards
Who cares. We all know the coupler will be fine. He has it in writing that the professionals said it's good to go. His *** is covered.
