U2110 Code
I wanted to check and see how long it had been since any codes were cleared and it had been 11 warm up cycles and 200 miles. I code of U2110 was set, yet no check engine light.
A search of this forum returns no hits. Has anyone else experienced this issue and what have you done to fix it? Like to know before I contact the dealer in the morning.
here’s what I see online:Make:FordCode:U2110Definition:Throttle/Pedal Position Sensor/Switch A Communication Circuit HighDescription:This DTC sets when the electronic throttle control (ETC) throttle position (TP) signal is too high.Cause:
- TP circuit open
- TP circuit short to voltage
- TP circuit short to VREF
- ETCRTN circuit open
- Damaged TP sensor
