Wow! No response, I guess that was a tougher question then I thought.
After a google search, I found the code P0122 implies a (TPS) Throttle Position Sensor. When I checked the TPS, the wire connection was loose. I secured it in place with a zip tie but I guess the damage was done so I replaced the TPS with a new one, cleared the code, and now all is well.
