Bed light duty winch install
Old Aug 10, 2025 | 06:11 PM
giant futon's Avatar
giant futon
What about a “Toy Loader” bed winch? There’s someone who makes a pre-engineered mount that mounts higher for a more straight line pull.
Toy Loader is the brand name
GF
Old Aug 11, 2025 | 07:44 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Originally Posted by traveldawg
I was going to suggest that for such a light load you could use a portable Warn winch. But I think those are only 120v AC. I didn't see one that is 12v. Just connect it to a goose ball and pull the load up into the bed and then roll it where you want it since it is on a dolly.
When looking I came across this portable winch set up. Looks like it could be pretty handy. I wonder if anchoring to the 2 tie downs on the lower part of the front bed would be enough to support pulling a few hundred pounds.
12VDC light-duty winches exist - I have one in my garage that I haven't used in years. Haven't needed one to be honest.
Old Aug 12, 2025 | 12:00 PM
jsavelli's Avatar
jsavelli
Winch for rear hitch need to figure out a front hitch n get removable winch n stow away in tool box
Any resources are helpful thx
Old Aug 13, 2025 | 01:12 AM
BeringF250's Avatar
BeringF250
Like giant futon suggested. Here’s this:
https://www.discountramps.com/truck-bed-winch-mount/p/Toyloader/?srsltid=AfmBOopgY6GZ79Qqbav431tAbeUNI3mQCK4A2m-wShAiuYlamr-gHCSQ
Old Aug 14, 2025 | 04:46 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
You can reuse the bed bolts. Hundreds of thousands (millions?) of trucks that have had a spray-in bedliner applied had their bolts reused....mine included.
I'd find a 4" wide piece of 1/4" flatbar long enough to catch both front bed mounts. Weld a 2" receiver to it, and bolt it down using the bed bolts. Might even be able to use angle iron, but I'd worry about stuff getting stuck behind the vertical leg, under your toolbox.
Trucksnguns
Mar 14, 2025 03:42 PM
Pkusa
May 28, 2023 11:08 AM
ron2565
15
Oct 28, 2021 02:49 AM
yitbos1
Mar 5, 2019 09:05 AM
