Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Decode please!
Old Jul 13, 2025 | 02:18 AM
The Extractor's Avatar
The Extractor
Decode please!
I saw this truck semi local and it looks to be in decent condition and it has 22.5 rims. Former u haul truck with a pallet flat bed haha.
I am contemplating buying it.
F60CCF90452
194 F603 4831 A?or4? 64
17000 164 3800 870437
Thank you!
Old Jul 20, 2025 | 11:18 AM
The Extractor
22.5 rims
22.5 rims
Door tag
Door tag
Old Jul 20, 2025 | 03:51 PM
85e150's Avatar
85e150
F60 = F600 gas, 4x2
C = 330 2V MD FT gas V8. (Medium Duty = 360 cast crank, FE distributor and oil pump drive)
C = Ontario Truck Plant, Ontario Canada.
F90452 = 1969 numerical series. The MPC shows the numbers going through G30,000. But the shop manual stops at F63,999. Mid to late 1969 production.
194 = 194 inch wheelbase
No color code. This is a U-Haul special order so it was painted a non-standard color.
F603 = F600 gas, 4x2, 17,000 lbs GVWR
4381
43 = Black Woven Plastic/Corinthian Rib/Corinthian Vinyl
81 = Standard cab, cab and chassis vehicle
A = New Process model 435 four speed transmission
64 = Rockwell model F-106 single speed rear axle, 15,000 lbs capacity, 6.80 ratio
No front axle code. For MY '64 to '69 only optional axles were listed. Thus the standard Ford axle, probably 4,500 lbs capacity without power steering. There will be markings on the axle to identify it.
17000 = 17,000 lbs GVWR
164 3800 = 164 Certified Net HP @ 3800 RPM
870437
87 = Body Company. All U-hauls show this as they went off to get their paint and box etc for rental duty.
0437 = Special order number
If the rest of it is in as good condition as the paint and warranty tag, that would be nice--other than the 4 speed and single speed axle which will be ok in town but not so much on a hill with a load....
Old Jul 20, 2025 | 08:03 PM
The Extractor
Thank you ! Very much appreciated. I like Bump sides better than my dent sides and it has a title and the 22.5 rims.
csnow
Nov 28, 2017 04:02 PM
kcb37
Jun 25, 2006 02:55 PM
Quadiquizm
Aug 10, 2002 01:17 PM
66camperspecial
May 24, 2002 12:23 AM
