Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Clark 285VHD input shaft question
Old Jul 9, 2025 | 07:11 PM
djhochmuth's Avatar
djhochmuth
1st Gear
Sorry if this is in the wrong area for starters.
I have a Clark285VHD with a long input shaft that I was trying to swap into a 1978 F700 that originally has a Clark 285V33 (locked up due to previous owner ignorance/stupidity) that has a short length input shaft. Before I go through the effort of trying to source a local transmission rebuilder I was wondering if they make input shafts that are shorter for the 285VHD so i could swap it in easier, or if anyone knows if i could directly swap a 285v33 input shaft directly on a 285VHD.
Also when measuring the input shaft length to order I just measure overall length of the shaft right? just front tip all the way to the back of the gear correct?
First time working in depth with transmissions for sorry if these are basic questions.
Old Jul 9, 2025 | 08:53 PM
85e150's Avatar
85e150
Welcome to FTE!
This is the right place for medium and heavy trucks.
Kind of a long shot question but if anyone knows they'll chime in.
Old Oct 7, 2025 | 07:55 PM
DrCharles's Avatar
DrCharles
If you're still looking, try comparing the various input shafts from the 280V series vs. the 280VHD series. Here are some relevant part numbers and dimensions. Hope that helps.
File Type: pdf
File Type: pdf
DieselDog409
Apr 27, 2023 08:45 PM
jolinbrown
Bronco II
18
Mar 18, 2008 01:28 PM
65comet
Feb 9, 2005 01:20 AM
Darrin
Jul 1, 2003 04:59 PM
