Steering Screeching sound
Old Jul 8, 2025 | 02:13 PM
cooperkoh's Avatar
cooperkoh
Trailering
1985 F-350 460 4spd. When I turn my steering wheel even a little bit something is making this awful screeching sound that is insanely loud, I replaced my power steering pump and lines but that did not fix it. Is it the steering gear? When im in 3rd its loud but when im in 2nd you can probably hear it from blocks away. If i keep the wheel dead straight it makes no sound but even turning it barely at all it screams.
Old Jul 8, 2025 | 02:50 PM
Brnfree's Avatar
Brnfree
Sound like a loose belt or the power steering pulley is out of alignment with the other pulleys.
Old Jul 8, 2025 | 05:06 PM
Franklin2's Avatar
Franklin2
Belt is slipping. Let me guess, it's lifted with huge tires.
Old Jul 8, 2025 | 07:58 PM
FuzzFace2's Avatar
FuzzFace2
I would start with the belt but look them all over.
How did you bleed the air out of the system when you replaced the pump and hoses?
How long since you replaced them?
What did you use for fluid PS fluid or ATF and what kind as there are different kinds.
Dave ----
Old Jul 8, 2025 | 09:54 PM
kr98664's Avatar
kr98664
Inspect the belt for any glazing. If unsure, just replace it.
Try a little belt dressing, too. See if that helps.
Old Jul 9, 2025 | 02:29 PM
FuzzFace2's Avatar
FuzzFace2
Just a thought if it makes the sound at idle take a little water in a spray bottle and spray the PS belt and see if the sound goes away.
You can spray the other belts 1 at a time to see if it is one of them too.
If it is a belt it may go away for a bit or change the sound pointing to the belt and not the pump.
Dave ----
Old Jul 9, 2025 | 05:38 PM
cooperkoh's Avatar
cooperkoh
Trailering
Completely stock
Old Jul 9, 2025 | 07:18 PM
Denzil B's Avatar
Denzil B
Originally Posted by cooperkoh
Completely stock
Sounds like a loose or slipping belt. That may not be the problem but you should eliminate that as the cause first.
Old Jul 10, 2025 | 09:46 AM
soybomb's Avatar
soybomb
Had sorta the same issue with my steering but not nearly that bad. Swapped out the belt and it went away. As the new belt stretched it began to get noisy again so i just need to extend on the bracket periodically to keep it tight.
Old Jul 10, 2025 | 02:41 PM
Max Capacity's Avatar
Max Capacity
There is something checking the amount of flex in the belt. You check it by pushing down in the center of the belt between the pulleys, I think there should be 1/4 to3/8 inch of movement... ? If there's more, tighten the belt.
Old Jul 10, 2025 | 06:03 PM
BigBlue2's Avatar
BigBlue2
Side play will vary by belt location, distance between pulleys.. it's best to look up that information for the specific engine and pulley. You don't want to overtighten a belt.
Also as belts age they harden and crack. In this condition they should be replaced ASAP as they can wear out v-belt pulleys by abrasion. Not to mention fail and leave you stranded.
redman84
27
Dec 16, 2013 11:52 AM
Doucheatron
Oct 26, 2011 10:05 AM
FordTrucksRule
1997 - 2003 F150
Nov 21, 2005 08:14 AM
'92FlareSide
Nov 18, 2005 06:20 PM
TheDuke
Oct 26, 2004 04:20 PM
