Radiator fans issue
Old Jul 8, 2025 | 10:42 AM
unibody62's Avatar
unibody62
Radiator fans issue
While I was charging my AC, I noticed that electric fans started cycling to high speed, and then back to regular speed. Now, as soon as I start the truck, the fan goes on high, even though the truck hasn’t been running and is not heated up. The temperature gauge is normal, so I don’t know what’s going on. Any ideas anyone thanks in advance
Old Jul 9, 2025 | 11:58 AM
wulleebullee's Avatar
wulleebullee
High fans
Radiator fans immediately going on high in hot or cold temperatures, whether at operating temperature or not, can be caused by TXV, the expansion valve. This is a common issue in this series. It was the cause of mine.
Old Jul 9, 2025 | 01:47 PM
unibody62's Avatar
unibody62
Expansion valve in the A/C unit. I’m not real surprised, because the A/C acts like my ‘69 Tbird and it has a known bad expansion valve. I noticed that if I turn the air off, the fan settles down. I’m traveling 350 miles from home now, so it’s not a great time for faulty A/C. Good thing my wife isn’t along, she’d be miserable.
Old Jul 12, 2025 | 07:57 AM
projectSHO89's Avatar
projectSHO89
The computer controls the fan speed based on its inputs and programming.
Guessing as to the cause is usually unproductive. Looking at the underlying data usually is.
Old Jul 12, 2025 | 08:39 AM
HomerWinzlow's Avatar
HomerWinzlow
Overcharging the system can cause instant high pressure which will cause the fans to hit high speed to keep the system pressures from blowing up your compressor.
Old Jul 13, 2025 | 12:15 AM
unibody62's Avatar
unibody62
I wondered about that also, simply because after I added part of a can that I already had, it still seemed a little bit low. That can had a dial type gauge on it. The next can that I bought had a digital gauge, but it still showed not fully charged when I first put it on. But after I did a couple of cycles of 15 seconds each.(per the instructions on a can.) it suddenly shot up to overcharged, but the fan started running fast even before that. I’ll recheck the pressure when I get home and if it’s over, I’ll try to let some out.
Weroance
Oct 18, 2024 12:45 PM
Brian Ski 44
Escape & Escape Hybrid
Aug 28, 2024 10:11 AM
MikeNucci88
2015 - 2020 F150
19
Dec 17, 2022 02:11 PM
Kris Griffin
2009 - 2014 F150
Feb 23, 2020 07:37 PM
86bluetruck
1978 - 1996 Big Bronco
Aug 14, 2012 08:44 AM
