How can I see battery voltage on Ford Pass?
Old Jul 7, 2025 | 09:02 AM
Rod27's Avatar
Rod27
As title says, is there a way?
Old Jul 7, 2025 | 09:13 AM
Rich1961's Avatar
Rich1961
Not that I'm aware of. I see Oil Life, DEF level, and Washer Fluid.
Old Jul 7, 2025 | 10:05 AM
Rod27's Avatar
Rod27
bummer….i see tpm’s and fuel too. I got a “see manual” error and wrench icon on dash. Batteries are 35 months old and it struggled to start today so I know they are about to leave me stranded. Going to replace. Wrench icon disappeared after ran it for awhile.
Old Jul 7, 2025 | 11:33 AM
HorizontalHunter's Avatar
HorizontalHunter
I you don’t provide any truck detail but if it is new @35 months you are still in the B2B warranty, or within most battery warranties as well.
Mine failed during the B2B warranty but I opted to upgrade to AGM instead of going the warranty route as the batteries were junk and heavily gassing. I wasn’t interested in more junk.
You need a voltmeter to check the voltage and a scanner to check the code. Even though the light is out the code will still be there. I hate that these trucks don’t have a voltmeter.
Bob
Old Jul 7, 2025 | 11:37 AM
Rod27's Avatar
Rod27
2022 f350 srw with 10k miles. Bought it with 200 miles last fall.
batteries are disposable (regular lead acid 3years….AGM’s 4 years) so they lasted about the same amount of time on my 2019 and I replaced them.
Old Jul 7, 2025 | 12:05 PM
HorizontalHunter
About what I got out of my ‘22, bought in ‘21. Remember to reset the BMS when you change the batterie(s).
Bob
Old Jul 7, 2025 | 01:51 PM
Phillbo's Avatar
Phillbo
Strange that ford thought wiper fluid was a valuable monitoring spec but not codes. Would be nice if Ford Pass displayed codes. I'm sure it's doable.....
Old Jul 7, 2025 | 02:22 PM
Rod27's Avatar
Rod27
Bob
I’ll have to learn….thx
Old Jul 7, 2025 | 03:11 PM
HorizontalHunter
FWIW:
I used Forscan to change the battery type to AGM and reset the BMS when I did mine.
Bob
Old Jul 9, 2025 | 10:59 AM
Dustin F450's Avatar
Dustin F450
Use a volt meter and check resting voltage after it sits overnight. Start it, turn everything o. AC, lights...it should go to about 14.8v briefly and taper off to 14-14.2 within a minute or so.
Mixplix
Apr 11, 2023 11:43 PM
AK2NC
Nov 11, 2022 09:16 AM
qman
16
Jul 16, 2009 09:19 PM
Eric_F250
Jan 29, 2009 06:25 AM
Aekisu
Electrical Systems/Wiring
Jul 29, 2003 05:20 AM
