Oil leak
Old Jul 20, 2025 | 08:20 AM
caleb90's Avatar
caleb90
Temporarily Deactivated
Looks like the non serviceable plug is leaking on the pump.. now need to locate the bigger leak in the back of the motor. I am strongly thinking is the pan gasket leaking
Old Jul 20, 2025 | 08:31 AM
Pikachu's Avatar
Pikachu
Unless the pan has been removed before, it's sealed with Ford TA-31 sealant. Failure isn't unheard of, but it's relatively uncommon. Resealing the pan should be done with the engine upside down, on a stand.
Old Jul 20, 2025 | 08:35 AM
caleb90's Avatar
caleb90
Truck has a new front cover on it, I don't see any evidence of the motor being pulled. So they must have done it in cab, pretty sure you need to lift the motor and drop the pan to do that job correct?
Old Jul 20, 2025 | 10:15 AM
caleb90's Avatar
caleb90
Upon further inspection this morning with a light and mirror, it's not the non serviceable plug. It's the main gasket where it mounts to the front timing cover. Has a steady drip on the bottom opposite side of the lines and plug. Also it bubbles from the top of the gasket aswell. Willing to bet when they did the front plate they reused the old gasket
Old Jul 21, 2025 | 01:59 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Pics would really help my man.
Old Jul 21, 2025 | 08:22 AM
Pikachu's Avatar
Pikachu
Sounds like he's talking about the HPOP mounting gasket.
Rick62
6.7L Power Stroke Diesel
18
Jan 19, 2021 10:25 PM
Travis Shidemantle
32
Apr 10, 2018 09:07 AM
Mcnitchell
Apr 29, 2015 10:42 AM
fishmanndotcom
16
Jul 27, 2011 09:07 PM
Suber
Apr 8, 2007 03:40 PM
