help tracking down engine oil leak
Old Jul 25, 2011 | 08:04 PM
fishmanndotcom's Avatar
fishmanndotcom
the original problem that started all of my problems is the engine oil leak. i thought it was the valve cover/gasket so i replaced them. then i thought it was the turbo pedastal, so i replaced it with the EBPV delete with new o-rings... notta. then i thought it was the oil rail plug on the driver side, tightened it and it still leaks. one thing i noted yesterday was the leak seems to get noticeably worse when revving the engine. at idle it barely drips off the clutch cover. what on the back, driver side of the motor can leak oil that changes with oil pressure?
i am about ready to pull this damn thing out and start from scratch!
-cutts-
Old Jul 25, 2011 | 08:12 PM
rodneywar's Avatar
rodneywar
oil plugs can leak due to the orings going bad also is the valley by the hpop dry
Old Jul 25, 2011 | 08:31 PM
fishmanndotcom
no i have kept it clean and dry to make sure the leak is not coming from the HPOP/IPR
-cutts-
Old Jul 25, 2011 | 09:00 PM
ccarrier's Avatar
ccarrier
you sure its not the hpop o rings?
Old Jul 25, 2011 | 09:08 PM
fishmanndotcom
not 100% sure bout anything but the leak seems to be coming from the back side of the motor. also i replaced the stock hpop with a 17* a couple of years ago so the o-rings should be very new.
-cutts-
Old Jul 25, 2011 | 09:18 PM
91 Dually's Avatar
91 Dually
If the plug in the oil rail is leaking, tightening it will not help...only replacing the O-ring will
Old Jul 25, 2011 | 09:30 PM
fishmanndotcom
hmm good call. gonna have to look into that! thanks man
-cutts-
Old Jul 26, 2011 | 01:53 AM
BuckHammer's Avatar
BuckHammer
When one of my oil rail plugs was leaking, I replaced the O-ring and that fixed the problem. I used to leak a bunch of oil, and now it barely leaks, if at all.
Old Jul 26, 2011 | 06:24 AM
fishmanndotcom
alright other than one of the rail plugs is there anything else on the back drivers side of the motor that might be leaking? i cant see bc of the turbo and up pipes
-cutts-
Old Jul 26, 2011 | 09:55 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
-cutts-
Yes there ara a BIG bolts two in the rear and two in the front of the galleys that has an big o-ring and can leak oil.
Old Jul 26, 2011 | 10:02 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
This one
Replacement O-rings for Ford Diesel Engines
Old Jul 26, 2011 | 12:22 PM
fishmanndotcom
Originally Posted by RÖENTGEEP
thanks man, just bought $70 worth of orings from Bob
i hope to seal this baby up once and for all!
-cutts-
Old Jul 26, 2011 | 12:54 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
-cutts-
You are welcome, good luck.
Old Jul 26, 2011 | 09:08 PM
RRranch's Avatar
RRranch
take off your clutch cover and wipe off the back of the oil pan real good then feel it for a cut where the clutch cover contacts it. Be careful. It's usually sharp when it happens. This leak only leaks at higher RPMS usually when the oil is really slinging around in the pan. It's just barely above the oil level in the pan. I fixed mine with silicone. At Ford I had to replace the pan and modify the clutch cover a bit so it didn't touch.
If it is this then check all your bell housing bolts real good. Loose bolts and this problem seem to go together in my experience. I had three about to fall out when I got it and noticed the leak about the same time.
I found loose ones on 1 and 2 year old trucks with this leak too.
Old Jul 27, 2011 | 05:35 AM
RubberDuck's Avatar
RubberDuck
Jason, look at this thread I did a while back. This is what RRanch is talking about.
https://www.ford-trucks.com/forums/1...ver-issue.html
