TPMS error
Old Jul 4, 2025 | 06:49 AM
Dan1954's Avatar
Dan1954
TPMS error
My 2025 has just over 3000 miles. Recently I’ve been getting a low tire pressure message but the pressure reads both front and rear are only 1 psi different. Front are 63 & 62 psi, rears are 80 & 79 psi. I have the erroneous tailgate ajar message as well. Too much crap on these trucks. Anyone else have the low pressure message when unnecessary? Thanks
Old Jul 4, 2025 | 07:53 AM
TheCyborgSlayer's Avatar
TheCyborgSlayer
It’s possible it’s showing the error because your rear tires are overinflated. Max is 65, assuming you have a 250.
Old Jul 4, 2025 | 08:25 AM
6.2caribou's Avatar
6.2caribou
Not necessarily true. Max pressure is based on the tire used and the GVWR of the truck. My '25 F250 came with 275/65R18E tires and the door sticker shows max load at 75psi cold. My '17 F250 came with 275/70R18E tires at 65psi cold. 75psi cold can easily become 80psi+, with no errors, in 100deg+ temps.
Old Jul 7, 2025 | 05:34 AM
Dan1954's Avatar
Dan1954
Looked more closely at the TPMS display & noticed the pressure levels were reversed, around 60 psi in the rear & 80 psi in front! The dealership changed my oil recently & rotated the tires without changing the pressure. My F350 door sticker calls for 80 rear, 60 front.
Old Jul 8, 2025 | 12:56 PM
Gladstone's Avatar
Gladstone
There is another possibility… They set tire pressure correctly after rotating the tires but didn’t reprogram the tpms sensor locations. You’ll know as soon as you check the pressure.
mikemdd
Apr 9, 2022 12:58 PM
Gruntface
Apr 16, 2012 08:35 PM
Mmaxed
Nov 2, 2007 10:00 AM
oldbird1965
Feb 17, 2006 10:40 PM
4x4TX
Dec 9, 2005 02:28 PM
