84 4.9 ignition issues
Old Jun 28, 2025 | 10:14 AM
Black88's Avatar
Black88
4th Gear
Truck died and back fired couple times now won't start does crank but distributor button doesn't turn. Pulled dist and had a sheered pin in the gear(no signs of damage to gear itself)fixed pin and still won't turn. Removed timing cover to check the camshaft gears and no signs of damage?
Old Jun 28, 2025 | 11:51 AM
kr98664's Avatar
kr98664
Welcome to the forum.
Did the pin shear a second time? If so, is the oil pump jammed?
Old Jun 28, 2025 | 01:57 PM
Black88's Avatar
Black88
4th Gear
Not that I'm aware of.
Old Jun 28, 2025 | 03:43 PM
kr98664's Avatar
kr98664
But have you checked the new shear pin? Not a lot of other possibilities if the camshaft is turning but the distributor shaft is not.
Old Jun 28, 2025 | 03:44 PM
Franklin2's Avatar
Franklin2
Look at the bottom of the distributor, it's going to have a 1/4 hex drive or a 5/16 hex drive. Look down in the dist hole, you should see the oil pump shaft. Take the correct socket and some extensions. Make sure to tape everything together so nothing will fall into the engine. Slip the socket over the oil pump driveshaft and see if you can turn it around a couple of times. I bet it's locked up.
Old Jun 29, 2025 | 01:41 PM
Black88's Avatar
Black88
4th Gear
Just checked it did shear pinand wrecked dist.gears
Old Jun 29, 2025 | 01:51 PM
Black88's Avatar
Black88
4th Gear
Yep oil pump locked up thanks for the help
Old Jun 30, 2025 | 06:33 AM
FuzzFace2's Avatar
FuzzFace2
Sorry to hear that let us know what you find that locked up the oil pump to cause all this problem.
Dave ----
R&S20
Aug 14, 2022 11:55 AM
Irv60
Oct 16, 2017 08:14 PM
deadbishop12
Oct 13, 2010 07:01 AM
rich51fordtruck
20
Jan 26, 2009 09:00 AM
peachhead25
15
Aug 27, 2003 01:07 PM
