Does anyone make a 3" to 2" reducer....
Old Jun 23, 2025 | 01:12 PM
Phillbo's Avatar
Phillbo
3" receiver and a 2" shank on my WDH. I currently have to 2 reducers in the reciever but they are sloppy as ***** and I have to use an anti rattle to keep the shank from moving around when towing.
Does anyone make a single reducer that will allow a 2" shank to be used in a 3" receiver that actually fits tight?
Old Jun 23, 2025 | 10:29 PM
Phillbo's Avatar
Phillbo
Mad google skillz. My 2 minute search came up empty. Looks a little cumbersome without a flange to stop it from pushing in... thanks.
Old Jun 24, 2025 | 05:37 AM
shawnee1's Avatar
shawnee1
I don't know if you will be able to find a reducer that fits tight enough that it doesn't rattle some. You already have the two reducers. I suggest having the two reducers welded together or use an epoxy to bond them together. You will then have a single piece 3" to 2" reducer.
Old Jun 24, 2025 | 08:56 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
I, too, had a 3 inch receiver with 2 inch hitch. Ford supplied a 3 to 2 1/2 inch adapter and my previous truck, for supplied a 2 1/2 to 2 inch adapter. While I don't tow a heavy bumper putll trailer, and the sloppiness going down the road did not bother my, but it was a pita trying to get the hole lined up to install the pin. I too both adapter to the garage, held them together with a 5/8 bolt and nut and fired up the welder and welded them together. A little rattle can paint job and all looks good. It works great!
Old Jun 24, 2025 | 10:35 AM
ejkTN's Avatar
ejkTN
https://www.etrailer.com/s.aspx?qry=...Inch_to_2_Inch. This one looks nice: https://www.etrailer.com/Hitch-Adapt...337RTA302.html
Old Jun 25, 2025 | 06:32 AM
99powerstrokedF250's Avatar
99powerstrokedF250
As mentioned, the cheapest option is to epoxy or better yet weld them together, most of us either can weld or know someone who can.
Old Jun 26, 2025 | 02:10 PM
Phillbo's Avatar
Phillbo
Nice but not sure I like the way that last one sticks out so far... looks like it would add a lot of stress to the set up......
I wish i did but i don't have a welder.
Old Jun 28, 2025 | 01:11 PM
acdii's Avatar
acdii
Welding it the key.
Reason you don't see them is square tubing with 1/2" walls is practically non existent. . That Husky one is a rarity, grab it while you can. Closest I found had 2 1/4" opening @ $62 for 12" piece.
I would take the 2 piece one and weld the ends together and then to eliminate slop, weld a bead on the sides, then grind them until its snug.
Old Jun 30, 2025 | 12:04 PM
HRTKD's Avatar
HRTKD
I gave up on the reducers and went with a 3" shank. At the time, Andersen Hitches was the only one I could find. They're still hard to come by but a couple of other vendors have added the 3" shank.
Old Jul 11, 2025 | 09:20 PM
scottz99's Avatar
scottz99
Veteran: Navy
I replaced my two-piece reducer with the Husky 3"-2" single piece reducer. With the two-piece reducer, I had 1/2" vertical slop; now I have 1/16". Good call on the Husky.
Old Jul 12, 2025 | 09:45 AM
Superdave71's Avatar
Superdave71
I second that on the husky! My Anderson WDH has been sitting in the corner because I didn’t want to use two reducers, and never got around to buying a 3” shank after I bought my 2020. Pulled the TT this weekend with the Husky/Anderson and it was a nice contrast to just a standard ball. The husky adapter is a great find!
yardbird
General Automotive Discussion
Aug 29, 2024 07:44 PM
Scottay
13
Sep 1, 2020 07:19 AM
dinebito
Escape & Escape Hybrid
19
May 21, 2009 03:42 PM
NewJim
All Things Towing
Sep 4, 2004 10:31 PM
topfisherman
All Things Towing
May 6, 2004 04:44 PM
