1993 F250 with 7.5L. I've been fighting a coolant leak that appears to be at the upper radiator hose connection to radiator. Got new hose and clamp. I keep snugging it, trying not to overdo it. The weird thing is that I'm seeing coolant pretty far from the cooling system, like over on the battery tray and on the charcoal cannister (??) attached to the side of the battery tray. Not super easy to see in the pic, but the side of the battery, the tray and the cannister are wet. Evidence on the top of the radiator neck as well. My best guess is pinhole or hairline crack on radiator neck spraying over there. I don't want to replace it if someone here knows better though. Any other ideas?
