Head gasket?
Old Jun 21, 2025 | 01:59 PM
95_460's Avatar
95_460
Head gasket?
My 95 F-250 with a 7.5L keeps getting hot on me. Both at idle or highway speeds. I have a new aluminum radiator with electric fam conversion. I'm running a 160 degree thermostat. It seems to be moving coolant fine and there are no leaks. What makes me think it could be a head gasket is that if I start it cold without the radiator cap on within about 10 seconds it starts pushing coolant out of the neck. Also it looks like there are a bunch of tiny bubbles as well. Is there a good way to check for sure without any specialty tools? Or any other ideas would be great as well.
Old Jun 21, 2025 | 02:38 PM
My4Fordtrucks's Avatar
My4Fordtrucks
The computer is set up for a 192/195°F thermostat why did you install a 160° thermostat? Did the engine do the same thing with the mechanical fan or is this new to the electric fan?
Old Jun 21, 2025 | 02:56 PM
95_460's Avatar
95_460
I put in a 160 to see if it would help it run cooler. It does not. It did the same thing with the mechanical fan. I decided to try out the electrical ones when I had to replace the original radiator. Neither change has made much difference.
Old Jun 21, 2025 | 03:44 PM
GoinBoarding's Avatar
GoinBoarding
You can check for hydrocarbons in the coolant. There are relatively cheap tools to do this. But this does sound like a leaking head gasket. You can also pressure test the coolant system. If I recall right they're supposed to hold 13 psi.
Old Jun 22, 2025 | 10:22 AM
wwhite's Avatar
wwhite
Do you actually loose coolant after driving?
Old Jun 22, 2025 | 12:41 PM
95_460's Avatar
95_460
Nope. I never let it run long enough to boil over.
Old Jun 22, 2025 | 01:36 PM
95_460's Avatar
95_460
So I bought a combustion gas tester and it looks like I am getting exhaust in the cooling system. Guess I will have to quit hoping it was something else.
Old Jun 28, 2025 | 01:46 PM
95_460's Avatar
95_460
Well I decided to try and run some blue devil head gasket sealer through the cooling system and I am no longer getting exhaust in the system. However the truck is still getting hot, especially if the AC is running. Going down the highway it's sits on the L in normal. Once I get into town or stop it starts climbing higher. Without the AC on it rides on the M ay highway speeds.
ola1234
Feb 17, 2007 07:33 AM
yabbie55
Oct 14, 2005 08:11 PM
vulch
1983 - 2012 Ranger & B-Series
Nov 28, 2004 02:37 AM
motorhead_83
13
Nov 9, 2003 09:30 PM
oldfordtrucksrule
15
Mar 9, 2003 01:01 PM
