Radiator-problem?
Old Feb 16, 2007 | 04:07 PM
ola1234's Avatar
ola1234
Radiator-problem?
Greetings from Norway!
Thank you all for a lot of useful information. Have been member for a while,
but not posted anything before. Guess i`m afraid my english is too weak...
I`ve got an -91 F-250. The last days i have notized that my radiator is leaking.
It seems to start leaking after the thermostat has opened. I also notized that
it seemed to be quite a lot pressure in the cooling-hose between the pump and the radiator. Could it be that the radiator is "plugged"?
The temperature is possibly a little higher then earlier. I have just had the truck for a few months, and yes the cooling-system should have been flushed. The liquid is dirty. But it is cold and snowy here right now, the plan was to flush it at spring. Or could it be anything else being wrong?
Old Feb 16, 2007 | 06:52 PM
Mr. Bob's Avatar
Mr. Bob
I had lots of pressure in my cooling system too...mine turned out to be a blown head gasket, but I didnt think that 7.3Ls were known for head gasket failure....
Old Feb 16, 2007 | 07:15 PM
matts156's Avatar
matts156
Heck, your English is better than some of the people who post here!
If a blown head gasket is pressurizing your cooling system, you should be able to see bubbles at the filler neck while it's running. You can also look to see if you have engine oil pooling up there, too, which would indicate a gasket leak between a water jacket and an oil galley, but that's a less common failure, and it wouldn't pressurize your cooling system. That's a quick and easy way to check for head gasket failure. Less quick and certainly less easy is a compression check, which would be no fun during a Norwegian winter.
If your coolant is that dirty, you may want to consider a new thermostat when you have the system flushed. I would try to do it before spring. That's a long time from now to run on dirty coolant, especially if you're noticing operating temperature increases over the last couple of months.
Old Feb 16, 2007 | 07:26 PM
Mr. Bob's Avatar
Mr. Bob
You could not see bubbles in mine, but if you filled the rad, put the cap on, and went for a drive, it would fill the overflow bottle with coolant and then it would start to overflow... once the rad reached a low enough level it would stop doing this....
Old Feb 16, 2007 | 07:36 PM
matts156's Avatar
matts156
Hmmm... yeah, if the leak was in the back of the motor, you might not see bubbles from the radiator at all. They could be forming too far away from the radiator to reach it.
Old Feb 16, 2007 | 09:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle
ola1234,
Welcome to FTE and the IDI diesel forum.
Where are you seeing the leak at?
Do you notice the coolant being pushed into the recovery tank and not drawn back into the radiator when the engine gets cold?
We have another user from Norway in here from time to time, he has a 7.3 turbo in a boat if I remember correctly.
Old Feb 17, 2007 | 05:39 AM
ola1234's Avatar
ola1234
I`m not sure where the water comes out, but it looks like it is coming out of the upper part of the rad itself , and then hits the fan and is thrown around in the engine room. The recover tank is not getting filled up. When i stop the engine nothing particuarly seems to happend. But it is guite some pressure in the upper hose(between thermostat and rad.) If i pull of the rad-cap it overflows.
Old Feb 17, 2007 | 07:33 AM
PLC7.3's Avatar
PLC7.3
Once the coolant is warm/hot it will always overflow when under pressure when the cap is removed.
Check the rad cap it has a pressure # like 13lbs what is yours. Be advised the upper rad hose will get hard enough you can't squeeze it flat, that is normal. Check your upper hose clamp especially if you still have the spring clamp you may wish to replace it with a gear clamp.. Quite often the rad upper tank solder seal will leak and coolant will run along the groove which gets confusing as to actual location. Find a garage with a cooling system pressure tester, they will pump the rad up until it shows the leak area.
