Sponsored by: Real Truck
NEED HELP FAST
Old Dec 29, 2002 | 01:49 PM
Starratt04's Avatar
Starratt04
NEED HELP FAST
im trying to take off the y pipe on the back of the turbo casue i broke one of the bolts off in it so i have an exhaust leak. ive got the up pipe off and the turbo is loose. there is a clamp holding the y pipe to the turbo. it is the same clamp that holds the down pipe to the turbo. i have both clampslose but they wont budge? how the heck do i get these things off? please help i need to get this thing back by tomarrow
1999 f-250 s/c psd lariat 4x4 off road
Old Dec 29, 2002 | 03:08 PM
Starratt04's Avatar
Starratt04
NEED HELP FAST
anyone else?
Old Dec 29, 2002 | 03:29 PM
Gwilkrrs's Avatar
Gwilkrrs
NEED HELP FAST
wish i could help.....
Old Dec 29, 2002 | 03:51 PM
DCSpecial's Avatar
DCSpecial
NEED HELP FAST
[updated:LAST EDITED ON 29-Dec-02 AT 04:53 PM (EST)]When I did the exhaust on my 01 PSD I believe the clamp that holds the downpipe to the turbo had a spot weld holding it on. I popped it off with a pry bar if I remember correctly, it was a while ago memory a little fuzzy.
Edit: if yours is the same the clamp should be loose except in one small spot, that's were the weld is.
Old Dec 29, 2002 | 04:59 PM
Starratt04's Avatar
Starratt04
NEED HELP FAST
ok hey thanks you all i got it off with a hammer hitting it thanks alot.
Old Dec 29, 2002 | 08:22 PM
Ghostrider304's Avatar
Ghostrider304
NEED HELP FAST
You might want to try using a screw driver to pry under the the "V" shaped cup that holds the to pipes together.
Will-
Old Dec 29, 2002 | 09:36 PM
4x4x4x4's Avatar
4x4x4x4
NEED HELP FAST
Crazyotto1
Nov 13, 2014 04:55 AM
AndeyHall
Jul 11, 2011 10:32 PM
johnsjsj
Sep 17, 2010 06:35 AM
schmuly
Mar 8, 2008 08:39 PM
bloomy63
Sep 3, 2006 02:45 PM
