'69 F700 decode request
Welcome to FTE!
F70 = F700
D = 330 2V HD FT gas V8
U = Louisville Assembly Plant
F53825 = 1969 numerical series, August 1969 production
156 = 156 inch wheelbase
EM
E = Light Blue
M = White
F702 = F700 gas, 23,000 lbs GVWR, "Except State of PA"
B281
B2 = Light Blue Woven Plastic/Corin Rib/Corinthian Vinyl
81 = Cab and chassis vehicle. In conjunction with "B2", Custom Cab. Cataloged as 81B.
2 = Clark model 282V five speed direct transmission
E3G
E3 = Eaton model 16244 two speed rear axle, 17,500 lbs capacity, 6.50 / 9.04 ratios
G = Ford-Rockwell (Timken) front axle, 7,000 lbs capacity.
23000 = 23,000 lbs GVWR
164 3800 = 164 Certified Net HP @ 3800 RPM
431220
43 = Milwaukee District Sales Office
1220 = Special Order Number. There are no blanks for color, axles, transmission, or engine, so what the special order was is unknown.
You indicate this is a '67 but the VIN is for '69. Does your title vin match the warranty plate?
F70 = F700
EM
E = Light Blue
M = White
B281
E3G
431220
