Does anyone else have the check engine light come on periodically with the code P0455. I have replaced the gas cap. The check engine light has still come on after that but not as much. Thanks.
2016 F250 4x4 XL 6.2 liter gas
Need a little more info on the truck...engine, year would help.
Could be evap canister, could be a leaking hose...could be you're not tightening the gas cap enough - three clicks is the recommended minimum, I always just give 'er a good twist and make sure it's well more than 3.
