Code 452 logical troubleshooting plan?
Old Jul 26, 2025 | 03:37 PM
  #46
72 F100 4x4's Avatar
72 F100 4x4
You bought an oscilloscope, now buy a breakout box?
Or
You can just back probe both components to do the same thing without one
I have one and have not used it in 20 years
Your '96 F250 should be OBD1 with a 60 pin processor and uses the 60 pin breakout box
If you lived near me, I'd just let you use mine
My breakout box is old and hammered, has at least one pin that does not work (EVP pin I believe)
We all learned to backprobe EVP's first for that reason
That is also the reason I got the old one when the dealer I worked for got a new one
They are on Ebay cheap at times, just like the NGS youi need
I was just reading through the Test Step DS1 yet again and more thoroughly, and I figured out that I was not using the step correctly. I'm sorry for the confusion. It looks like I can just unplug the connector from the PCM, and measure resistance across pins 3 & 6 with an ohmmeter. I think the o-scope shows that the signal coming from the PSOM is good without the Speed Control Module connected, but I'm not sure and a resistance check should be easy. I should be able to get that done today.
Just FYI, I thought that the yes or no applied to the first sentence of the test step " Continuous Memory DTC 452 indicates", etc. I see now that the yes or no applies to the question at the bottom concerning the resistance check. It seems kind of obvious now that I've figured it out, not so much when I was looking at it before.
Old Jul 29, 2025 | 09:16 PM
  #47
72 F100 4x4
I finally got around to checking the PSOM resistance, it's at the low end of the range, but in. - 21.5k ohms.
I also figured out a little bit ago that the CHARM link is interactive, I wish I would have figured that out a long time ago. It shows the resistance limits for the ABS / VSS sensor, 1300-1550 oms. Mine is at 1072 ohms. I guess I'm on the hunt for an ABS / VSS sensor. I have seen posts saying that aftermarket sensors are not so good, but I believe they were all older posts. Is that still the case? Should I try to find an OEM Ford part?
72 F100 4x4
Jun 18, 2025 05:25 PM
gapman789
Nov 3, 2017 07:17 PM
mechmagcn
Arkansas Chapter
Jan 4, 2016 06:05 AM
Fett Affen
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Apr 3, 2009 10:24 AM
playbass48
1983 - 2012 Ranger & B-Series
Aug 25, 2006 11:44 AM
