To much vacuum
Old Jun 18, 2025 | 10:18 AM
Somegaveall69's Avatar
Somegaveall69
3rd Gear
To much vacuum
Hi all
my 69 360fe
I have replaced lifters,push rods, intake gasket, carb, distributor, double roller timing chain In the old boy and it is sucking way way to much air. Timing has been set and checked many times. Has a Rolling miss and loss of power. Does not smoke or use oil. Absolutely clean straight original truck. Really need help to figure out what is going on!
any help is appreciated
Old Jun 18, 2025 | 11:16 AM
Centennial F100's Avatar
Centennial F100
What carb do you have, and have you done a vacuum test?
Old Jun 18, 2025 | 11:21 AM
Somegaveall69
3rd Gear
Running autolite carb, oem do not have a vacum gauge.
I have to block off blow by hose to keep it running.
Old Jun 18, 2025 | 11:47 AM
davelj's Avatar
davelj
It's a guess but maybe the intake gasket slipped when installing the intake.
Old Jun 18, 2025 | 11:49 AM
Centennial F100
I am no expert, and my engine has not been refreshed like yours, but recently my engine was suddenly bogging down and stalling when I went off idle. I started a thread that received lots of replies and suggestions that may be helpful to you. The thread was started June 12th,is titled : Engine bogging down on acceleration.
Old Jun 18, 2025 | 12:25 PM
blue68f100's Avatar
blue68f100
I'm with the ones thinking you may have slipped the intake gasket trying to set that 90# intake on. Also makes me wonder if you got the cam and crank clocked right. 1 tooth off will act the same way.
Old Jun 18, 2025 | 12:46 PM
Wangdangdoodle's Avatar
Wangdangdoodle
This, most likely. Easy to check. Pull off that front cover and take a peek.
Old Jun 18, 2025 | 08:01 PM
blue68f100's Avatar
blue68f100
Originally Posted by Somegaveall69
Hi all
my 69 360fe
Why were you replacing the lifters and push rods? Lifters dished? Installed cam? Remember these old engines require a HIGH ZINC Oil to prevent wear on the cam and lifters. Most oils these moderns oil are designed for roller cams which do not.
Old Jun 25, 2025 | 12:17 PM
Somegaveall69
3rd Gear
truck set for years and although I pre lubed everything prior to running it. When I shut it down and went to start it later the perafin on the valves had stuck several of them. Bent push rods. So I just replaced all of it after spending hours freeing the valves. Cam is still in good condition. I run additives in the oil.
Wolffman
32
Apr 1, 2014 01:21 PM
BossFan
Aug 13, 2011 04:35 PM
j_crista
13
May 1, 2010 12:10 AM
my69ford
Jun 1, 2006 12:10 PM
hartattack
Jan 22, 2005 08:36 AM
