I need help. I cannot for the life of me locate the "plug" where the in-cab tank sending unit plug, plugs into behind the instrument cluster. Does someone have a picture of it?
back story. The PO had the sending until wired into a bosch fuel gauge not even designed for the ohms rating of the sending unit. So 1/2 tank = empty
I've installed a new printed circuit board behind the IC along with a new voltage regulator needed for the gauges to work properly. What-DA-ya-know... the factory fuel gauge works. Now I just need to find the plug.
