rear discs
Old Jun 16, 2025 | 04:58 AM
gambling209's Avatar
gambling209
rear discs
i know this has probably been covered, but a quick search turned up nothing. i have a 79 f350 4x4 that i am redoing. i want to convert the rear to discs. the question is about the master cylinder and proportioning valve. i know you should use disc stuff. what is everybody using? thanks
Old Jun 16, 2025 | 01:42 PM
mac.motorworks's Avatar
mac.motorworks
For what it's worth, I'm using the proportioning valve that came with a new power booster I ordered. Looks pretty plain-jane, no adjustment or anything, just have to attach to master cyl and then route the rigid lines to L/R front, 1 line to rear. I trust/hope that it's correct as there is no way to "proportion" brake fluid. Seems like it should be plug and play. I've not got this fully plumbed yet but once I do I can report back if you like
Old Jun 16, 2025 | 01:58 PM
gambling209
i would like to hear how it works out. what is the bore size on your master cylinder?
Old Jun 16, 2025 | 02:03 PM
mac.motorworks
honestly I don't know. It was the only MC and booster for a 1974 with disc/disc setup... so I'm taking a leap of faith!
I bought it from CJPony so maybe take a look there... they seemed to have a pretty good selection process for what I needed
Old Jun 17, 2025 | 07:48 AM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
I am using the original disk/ drum valve on mine. I also switched to hydroboost. No problems here.
jazzyndon52
Jan 1, 2015 10:58 PM
troy676
20
Mar 9, 2013 08:31 AM
crazy96863
18
May 7, 2012 11:55 PM
tonpartain
Jun 6, 2006 10:06 PM
51fordrodder
May 10, 2005 06:10 AM
