Brake conversion question
Old Jun 6, 2006 | 04:03 PM
tonpartain's Avatar
tonpartain
Talking Brake conversion question
This will be my last question on this topic, I promise...
Of the two brake lines which connect to the master cylinder, which goes to the front inlet of the proportioning valve and which goes to the rear inlet of the prop. valve?
My guess would be that the outlet closest to the booster on the master cylinder connects to the front inlet on the prop. valve and the the outlet on the rear of the master cylinder connects to the rear inlet on the prop. valve. Is that right?
Old Jun 6, 2006 | 06:04 PM
Mil1ion's Avatar
Mil1ion
On what year ?
Your profile says a 72
Below is one from a 78/79
https://www.ford-trucks.com/user_gal...=20541&width=0
It has a bleed pin on it.
Old Jun 6, 2006 | 07:09 PM
Mark63's Avatar
Mark63
The larger reservoir on the master cylinder is for front brakes
The small one is rear brakes
Old Jun 6, 2006 | 08:22 PM
Mil1ion's Avatar
Mil1ion
He is asking about the PPV not the master cylinder.
Old Jun 6, 2006 | 10:06 PM
tonpartain's Avatar
tonpartain
I'm asking about the lines from the master cylinder to the pv.
