What solved your death wobble?
Old Jun 15, 2025 | 03:56 PM
steelholder's Avatar
steelholder
So I'm trying to find the source of my death wobble, it's actually not a wobble at all but an up and down motion after I go over a large bump. Feels like something gets stuck like a strut or spring and makes the front end feel like I'm going over a set of speed bumps. I slow down and it goes away. The truck needed new inner and outer tie rods. I replaced those but it's still doing it. What worked for you guys?
Old Jun 15, 2025 | 06:50 PM
sswari's Avatar
sswari
Shock absorbers?
Jack it up by the frame and see if you can find anything loose.
Old Jun 15, 2025 | 08:09 PM
Duke5A's Avatar
Duke5A
Just like I posted in your previous thread, check the shocks. There is no rebound control when going over bumps.
Old Jun 15, 2025 | 08:54 PM
steelholder
Originally Posted by sswari
Shock absorbers?
Thanks guys I will check and report back.
Old Jun 15, 2025 | 09:05 PM
steelholder
Could you clarify what you mean by lack of rebound control?
Old Jun 16, 2025 | 07:49 AM
Rusty Bucket Ohio's Avatar
Rusty Bucket Ohio
Originally Posted by steelholder;[url=tel:21593479
21593479[/url]]So I'm trying to find the source of my death wobble, it's actually not a wobble at all but an up and down motion after I go over a large bump. Feels like something gets stuck like a strut or spring and makes the front end feel like I'm going over a set of speed bumps. I slow down and it goes away. The truck needed new inner and outer tie rods. I replaced those but it's still doing it. What worked for you guys?
Mine was a caliper that was slow to release… I put a new set on and solved the issue
Old Jun 16, 2025 | 08:40 AM
1Butcher's Avatar
1Butcher
You need to have someone drive beside you so they can see what you are feeling. I had this early on my 95 F250 and it was not until my wife was driving and I happened to be driving next to her before I could see what was happening. The wheels were going side to side, not up and down. Dampening worn out parts is a band aid, not a solution.
Heck, maybe a GoPro will be helpful.
Old Jun 16, 2025 | 08:48 AM
Duke5A's Avatar
Duke5A
Shocks dampen the rate the coil springs compress and decompress. Your shocks are shot and the front end is bouncing around as a result. Pull one of the front shocks out and I bet you'll be able to push it in and out by hand with no problem. They're not expensive and easy to replace.
BigRed7.3l
Nov 23, 2013 12:15 PM
LSO1123
May 25, 2012 04:30 PM
hobbs53
Oct 29, 2011 07:09 PM
Blue69gt
1983 - 2012 Ranger & B-Series
Mar 19, 2006 02:38 PM
horseshoeing
Sep 7, 2004 08:59 AM
