Help Needed: 2009 Ford F150 Body Control Module Issues
The Problem: The dealer claims it’s a bad Body Control Module (BCM). They ordered replacements 2-3 times (they were cagey about specifics), but each time, the module wasn’t programmed right for my truck and failed. Honestly, it felt like they weren’t equipped to handle this and kept me chasing updates. On my last drive before it died, the dash gauges went wild, throwing charging system errors. I got it to start once or twice afterward, but now it’s completely dead—no power at all. This truck was running great before this, and I just put new tires on it, so I’m eager to save it!
Questions for the Community:
1. Has anyone dealt with BCM issues on a 2009 F150 or similar Ford? What fixed it?
2. Any tips on ensuring a BCM is properly programmed for my truck? Is this strictly a dealer job, or are there specialized shops or tools I can explore?
3. Could the charging system errors or erratic gauges point to something else (e.g., wiring, alternator, battery) that’s messing with the BCM?
4. Bay Area Folks: Can you recommend shops or mechanics in the San Francisco Bay Area who specialize in Ford electrical issues, especially BCM-related problems? I’m willing to tow it to the right place for quality work.
5. Any DIY troubleshooting steps I can try to pinpoint the issue before taking it to a shop?
I’m desperate to get this rig road-ready for hunting season, so any insights, experiences, or leads would mean the world. If you need more details about the truck or symptoms, just let me know. Excited to join this community and grateful for any help!
Cheers
I have the truck back at my house. Took the fresh battery out of my other truck and when I go to start it the dash lights up and I have power in the truck, but I just get a small click out of the relay box. I’m in the relay box testing connections and relays now.
Not sure if that info points anywhere. I’ve heard it could be a bad alternator, or a bad ground somewhere. Maybe a corroded connection. Any help how to sort through these different items would be appreciated.
Add a clean, new ground wire between the negative battery terminal, frame, and engine. This is to rule out corrosion on existing ground and frame connections or even within the lugs’ connecting to the primary power distribution wires, a couple of times, I’ve found the wire inside the crimped connection to the wire to be corroded.
When trouble shooting bad power and ground connections, begin with getting a good clean connection to the battery positive and negative terminal to be used as references for your volt meter to identify the voltage drop of the wiring or connectors.
With someone helping to turn the key to attempt to start the pickup engine, check the voltage drop between your reference connection points and local power and ground points. You’re looking for voltage drop present in the distribution of power and ground using a volt meter while the key is on and the problem is present. The circuits must be drawing power from the battery to measure the voltage drop of a resistive or corroded wire or connector.
You will expect to find 0.1v drop, but anything more, especially 0.25v or greater is going to point towards a problem.
Begin by checking power and ground to the fuse box and panels, then primary starting circuits and BCMs.
From this point onwards one needs to have knowledge of the specific subassembly functions or BCM to identify the cause of a component failure.
