Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1983 F-600 Decode
Old Jun 13, 2025 | 08:23 AM
19adam99's Avatar
19adam99
2nd Gear
1983 F-600 Decode
We've still got this 1983 F-600 hangin' around at my workplace up here in Minneapolis, figured it would be worthwhile to get a decode on it, see what all it has.
​​​​Y'know, in the event they decide to part with it.
Has less than 75,000 miles on it.
VIN is 1FDNF60H4DVA06112, with the full tag posted below with a photo of the truck in question.
Old Jun 13, 2025 | 01:24 PM
85e150's Avatar
85e150
1FD = Ford Motor Company USA, incomplete vehicle
N = Class 6--19,501-26,000 lbs GVWR, hydraulic brakes
F60 = F600 4x2, gas
H = 370 2V, or 4V, or 2V Low Compression
4 = Ford check digit, ignore
D = 1983 model year
V = Kentucky Truck Plant
A06112 = serial number
153 = 153 inch wheelbase
9F = white
F603 = F600 bas, 19,700 lbs GVWR
FB8
I do not have upholstery info for this model year. "8" would indicate cab and chassis vehicle, as indicted above.
AA = Allison AT-545 automatic transmission
65K
65 = Rockwell (Timken) model F106 single speed rear axle, 15,000 lbs capacity. Ratio shows 6.83 for F600 but only '80 & '81. 7.17 for F700-900. There will be a label on the axle with the actual ratio.
K = Ford 5,500 lb capacity front axle with power steering.
587333
58 = Twin Cities District Sales Office
7333 = Special Order Number
A 370 with an automatic will be pretty slow and probably horsepower limited to a 50-60 MPH top speed depending on what kind of body is on it.
Tbounds02
Feb 1, 2025 05:35 PM
tjc transport
Large Truck
Dec 27, 2024 09:00 PM
Horseman73
Large Truck
Jan 11, 2023 01:15 PM
Drew Smith
Large Truck
Nov 29, 2021 12:42 AM
Al-Berta
Nov 5, 2021 08:44 AM
