Sponsored by: Real Truck
Help identify this tailgate please
Old Jun 11, 2025 | 05:54 PM
SWHoskins1's Avatar
SWHoskins1
Trailering
I have a 2000 F250 crew cab that is in overall excellent condition. One flaw was a dented tailgate where someone obviously dropped something heavy and creased the metal. I found this one on eBay that says it will fit 1999 - 2007.
I took pictures of the hinge points on the tailgate and the tailgate itself. The driver side of the tailgate doesn't fit. If I can identify the year, maybe I can swap out the post on the bed that it fits on to. Any help is appreciated.
The replacement tailgate
Passenger side of tailgatej
Passenger side post on the bed
Driver side post on the bed
Driver side of tailgate
Old Jun 11, 2025 | 06:18 PM
mterickson's Avatar
mterickson
If I were to guess it is a tailgate from an '11 or '12 Super Duty, in '13 they added a "trim line" near the top of the tailgate which is about a 1/4" wide indent running parallel with the top of the tailgate that shapes a "U" pattern to go around the tail gate handle.
Old Jun 11, 2025 | 07:52 PM
SWHoskins1's Avatar
SWHoskins1
Trailering
Thank you. I have messaged the seller to see what he says, but no reply as of yet. I appreciate the help!
Old Jun 12, 2025 | 06:10 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Looks exactly like the '08 tailgate (which would be '08-10 body style) that I put on my '04 years back.
The driver's side doesn't fit properly because of the rubber piece in the tailgate, which is part of the 'dampener' system that makes the tailgate not 'slam' down. There are two ways to make it fit, provided this is an '08-10 tailgate.
#1, and the right way, is to buy a driver's side hinge for an '08-10 truck and replace your hinge. It will bolt right on.
#2, and the way I did it because I didn't care about having the dampener, is to unbolt it from the bottom of the tailgate (IIRC the bolts are accessible from the exterior) and the rubber piece and the rod all slide right out. It has been YEARS since I did this (I think I did it back in 2013/14?), but I believe I had to open the access panel on the back side of the tailgate to remove the clip that holds the rod in place so it didn't rattle around inside. Once that rubber piece is out of the way it'll mate right up with your driver's side hinge.
Old Jun 12, 2025 | 10:13 AM
SWHoskins1's Avatar
SWHoskins1
Trailering
Thanks very much! You guys have helped tremendously and confirmed what hinge component I need to change. I found one locally that is fairly inexpensive. This forum and those of you in it are the greatest resource I have found for my truck. Thank you again!
Kman-S.E.USA
22
Mar 28, 2025 10:01 AM
73explorer
Sep 20, 2023 08:52 PM
Wbrian
2015 - 2020 F150
May 27, 2020 10:35 AM
keyul
Feb 4, 2012 12:34 AM
STLford
Jul 12, 2010 03:59 PM
