Lower Alternator bracket bolt 302
Old Jun 11, 2025 | 09:43 AM
lxer96's Avatar
lxer96
Anyone have any advice on getting the lower alternator bracket bolt back in? I pulled it out while replacing the alternator and now it won’t thread back in. Seems out of alignment or something. Threads are really gummed up with something brown/rusty colored. This is the long skinny bolt that bolts through either the water pump or the timing cover, not the shorter one that holds the alternator to the bracket.
After about 30 mins of trying I gave up to regroup. Ordered a long thread tap to clean out the gunk.
Old Jun 11, 2025 | 02:49 PM
Franklin2's Avatar
Franklin2
If the alternator has metal sleeves in the holes where the bolt goes through, knock these sleeves back to give you more wiggle room. The sleeves will move back in position once you start tightening the bolt.
Old Jun 11, 2025 | 03:13 PM
Max Capacity's Avatar
Max Capacity
Dave, I think he's talking about the bolt holding the bracket on the water pump.
Old Jun 11, 2025 | 05:05 PM
lxer96's Avatar
lxer96
That’s the one. I got it. My 6” 5/16-18 thread tap saved the day. Got all the years of built up gunk out and it threaded right it. No need to light my whole truck on fire this time. 🤣
Old Jun 11, 2025 | 05:08 PM
Max Capacity
Glad to hear it was an easy fix.
Frozen_Joker
Aug 20, 2016 03:03 PM
loksoff
Feb 21, 2014 01:33 PM
danlee
40
Feb 20, 2012 06:59 PM
dickdollar
Nov 23, 2003 10:07 PM
