2011 6.7
Old Jun 11, 2025 | 09:26 AM
kiing888's Avatar
kiing888
3rd Gear
ford f250 2011 6.7
Fuel filters replaced
Driver side fuel rail / fuel regulator replaced
tuned with a h&s 80hp tune and EGR deleted but not removed.
In the morning I start up my truck with the key and let it warm up for about 15 minutes. Once i’m in the car if i turn the ac off it will pump even more, but the fuel filter under the drive seat will start to pump. Once it reaches around 190 f it stops. Anything helps, thanks.
https://www.reddit.com/r/FordDiesels/s/qdIuoYaOo4
Old Jun 11, 2025 | 10:50 AM
F250_Super_4X4's Avatar
F250_Super_4X4
I am thoroughly confused at what the problem is?
If I understand your issue correctly you are wondering why your lift pump, pumps more (how do you know that the pump is pumping more fuel?) and then when the trucks fuel? Oil? Primary coolant? reaches 190f the lift pump turns off and the truck is defueled aka dead?
Old Jun 11, 2025 | 12:41 PM
kiing888's Avatar
kiing888
3rd Gear
Issue is the lower fuel filter pumping
My issue is that it starts to making a weird pumping noise and i don’t know why it does that. I provided a reddit link with a video of the noise while going like 50 mph temp around 160/170f. Sorry for the confusion
Old Jun 11, 2025 | 01:26 PM
F250_Super_4X4
Check your blowby
Start your truck and remove the oil cap.
If you see rushing smoke coming out of it, the issue may be your CCV is clogged up
Also warming up your truck for 15 min or more will cause severe fuel dilution in your oil. It is preferred to start your truck and begin driving right away not exceeding more than half throttle till the engine oil hits 100f.
Old Jun 11, 2025 | 01:33 PM
kiing888's Avatar
kiing888
3rd Gear
Check your blowby
CCV filter was also replaced not long ago but will check asap, thank you.
Old Jun 12, 2025 | 10:36 AM
Overkill2's Avatar
Overkill2
So I heard the popping sound, for lack of a better term, and you think it's coming from underneath the driver's side floor?
That could indicate the DFCM (diesel fuel conditioning module)... without knowing more but seems to be what you're saying.
So when you changed the primary filter there, you know there's two tabs that meet when the lower part I'll call the cap, is properly tightened up? One tab is on the top part of the pump where the hoses are and the other is on the cap. I shine a flashlight up behind there when I'm tightening the cap down after replacement. I also put fresh engine oil on the cap threads and new o-ring which makes it turn on much easier.
I'm wondering if the cap may possibly be sucking a little air.
I also prime mine at least 12 cycles... the 30 seconds the pump runs when you turn key on and engine off...
But that sure is a weird sound.
EgonAngler
Oct 12, 2023 05:51 PM
wigpro
Modular V10 (6.8l)
Jun 6, 2015 09:27 AM
damnedin82
39
May 2, 2008 10:27 AM
Nenzel
Jan 27, 2005 10:37 PM
Capt_Dunzell
49
Sep 17, 2003 07:24 PM
