Creaking sound after drive
Old Jun 9, 2025 | 02:57 PM
Vanhartman's Avatar
Vanhartman
Took my truck on the first drive in a while, only a spin around the block. Afterwards it’s making a creaking noise (see attached video). My shocks are trashed so I’m thinking that’s the culprit. Any help would be great.
1964 292 2wd
File Type: mov
Old Jun 9, 2025 | 06:03 PM
TA455HO's Avatar
TA455HO
Lead Gopher
If you can reproduce it take a section of 5/8” or 3/4” rubber heater hose about 2-3 feet long or a reasonable facsimile. Hold one end up to your ear while you hold the other end to each shock in turn and see if that’s where the sound is coming from. It’s a homemade stethoscope. Sounds are easier to pinpoint using the hose in this way. If not the shocks start moving the end of the hose to other areas. Try it! Usually works pretty well.
porterwagen
Sep 27, 2022 11:14 AM
95 f150.
May 25, 2020 06:42 PM
VinceDee
Oct 10, 2007 01:43 PM
Red Raider 4x4
Oct 30, 2005 12:54 PM
max82
Oct 29, 2003 09:26 AM
