Intake plenum question.
Old Jun 9, 2025 | 02:29 PM
Klutch5000's Avatar
Klutch5000
I likely know the answer but I'm trying to concince myself to leave them alone. Truck is 1996 with 80k miles, cnc hpop, stage 1's, KC stage 1, truck runs great. Thought I'd check for boost leaks anyway. Found a couple clamps that needed to be tightened. It now takes 3 minutes for pressure to drop from 25psi to 0. But.. spraying soapy water around, there are a few pinhole leaks on the plenums where the rtv silicone seals them. Very small leaks and like mentioned, 3 minutes for pressure to bleed off. Do I bother changing them/ resealing them?
Old Jun 9, 2025 | 02:56 PM
knottyrope's Avatar
knottyrope
if it drops from 25 to 20 fast, then I would re seal
Old Jun 9, 2025 | 04:13 PM
Klutch5000's Avatar
Klutch5000
9 seconds 25 to 20.
Old Jun 10, 2025 | 08:58 AM
knottyrope's Avatar
knottyrope
that sounds fast
Old Jun 10, 2025 | 09:17 AM
Klutch5000's Avatar
Klutch5000
that sounds fast
I think so too. Eyeballing the CNC fab plenum with gasket
ranagent
30
Apr 8, 2017 07:48 AM
tomthelegend
22
Mar 10, 2014 03:56 PM
SkySkiJason
24
May 26, 2012 08:27 PM
natewoz
15
Dec 9, 2008 03:24 PM
sgrol
Dec 14, 2006 11:40 AM
