What do you carry?
Anyway, from memory, here's my list. Prolly missing a few items. What would any of you add?
Spare belts
Rad hoses and assortment of fuel, transmission and heater hoses, etc
Spark plugs, cap rotor, spare pertronix, spare distributor, spare wires, coil
Carb kit including jets, power valves, diaphragms etc
Rad cap, gas cap
Starter. solenoid
Alternator, voltage regulator
Fuel pump
Wiper blades, spare bulbs
Head gasket in a can, radiator sealer, etc
Thermostat
Rtv sealant
Small wiring kit including some wire, connectors, tape etc
Tire repair kit including 12v compressor
Extra all fluids
Wd40 or Spray lube, Dry gas, Brake clean
Zip ties, Duct tape, Teflon tape, tie wire, hose clamps
Timing lite
As you can see, takes up less space than would think. As should be obvious, goal is to be able to deal with most anything short of catastrophic.
I do carry AAA for both the truck and trailer. Sometimes not practical tho and sometimes quicker to fix it and be on my way. Plus would most likely have it towed home and fix myself anyway so why go thru all that.
In all my years of wrenching could count on 1 hand times I needed a torch to make a repair. What do you consider it useful for?
and then I see we did get down to that! Impressive list of stuff you carry, I probably would do the same if I was traveling with mine, I do keep the basics in all of my trucks, tools, spare cap/rotor, belts, fluids, gorilla tape, zip tyes, bailing wire and band-aids
and they all have a pew pew and knife. I buy a toolbox for all my trucks since they are all reg cab, in my 4wd trucks I also keep recovery gear, shovel, bow saw, heavy rope along with the above mentioned stuff.
Where I go up in the mtns, ain't nobody coming to help, I also added a can of ether to fix a broken bead, used it once, saved swapping to my spare, note to self, don't drop below 10psi on the fronts with 305/75/16's on 10" wide rims 🤦♂️ duh, my bad.
If going up and I planned the trip, I'll throw my chainsaw and milk cate of chainsaw stuff in and strap it down, get some wood while wheeling and widen the trail where it needs it, never understood the SxS group, they will stop, cut a tree out of the trail, but... only wide enough to get the SxS through, seriously guys..?! 2 more mins and viola, whole trail open...
As far as the other things you mentioned, I'll add 1 more. Rescue boards. Seems nowadays eeeeeverybody needs rescue boards! Especially the trucks that I know have never even driven through so much as a puddle.
