Intermittent Wipers (and not the good kind)
Hey all!
OK, so it's raining like heck here in Oregon right now. I'm out driving the truck through this muck, and the wipers just stop on me as I'm driving...yow! I wait for a second, and as the winshield fills up with water.....nothing happens.
So, as I'm on the freeway doing 60, I have to do something...so I grab the wiper selector and click it down a notch on the speed...and the wipers come back...for a few minutes. They stopped again in the same way, so I flipped them back on to high, and they started again...for a while. I turned them back down to the lowest setting and they stayed on for the rest of the trip OK.
Voltage and everything was just fine FYI.
I'm thinking it's a switch problem, but I'd like to know if anyone else has seen this type of thing before, and if so what was your solution?
Thanks in advance...
Dan Martin
86 F350 Crew Cab Dually.
Dan Martin
sounds like a wiper motor. they are famed for problems on the early fords, mine currently will not shut off. had to install a toggle switch to shut the power off. tired of replacing it, it is my third one, its even under warranty. my first one did like yours did, run great, then just shut off. move the selector speed and it would work for a while. then it would shut off again, i would repeat it and it would work. after a little diag, i found that the resistor was heating up and shutting power off. i would get a copy off the factory ford manual, and pin it out before replacing any components though. let me know if you cant find one and i will help walk you through it.. Kurt
Ive always had problems with the int wipers. Had em when i first bought the truck but have weeded most of em out. First one the intermittent wipers wouldnt work only lo/hi and it wouldnt park by itself. Noticed when i would hit the dash by the wiper where the delay box was it would click and work sometimes. firgured it was a loose conneciton inside somewhere so replaced it with a junkyard unit. Worked for a while then the wipers stopped completely and the box would click and get hot. Took apart the wiper motor and it had bad windings. Replaced it, no more problems for now.
