P0320 code
Old Jun 8, 2025 | 04:08 AM
tomatogrower's Avatar
tomatogrower
P0320 code
I have a 1997 f350 with a 460 motor...the California truck has 357,000 miles on the odometer... so well worn... it has stalling issues at low speeds or at stoplights along with a check engine light on the dash... i ran a scan tool recently and it shows code P0320... i am assuming it to be a faulty PIP sensor in the distributor... i have replaced the ignition control module (ICM) recently on the driver's side fender ... i intend to replace the entire distributor for simplicity... any recommendations or comments are appreciated... thanks...
Old Jun 8, 2025 | 09:18 AM
1Butcher's Avatar
1Butcher
The ECU needs a crank signal and if it does not have one, then the engine does not run. If you don't have a stalling issue, I would look into what signal the ECU is looking for. I'm not certain if the engine has a separate crank sensor or if it's built into the distributor.
Old Jun 8, 2025 | 10:56 AM
rla2005's Avatar
rla2005
There is a misfire detector on your OBD-II trucks. It appears Code P0320 is triggered when two or more PIP pulses are detected. I believe you most likely have a failing PIP sensor (aka stator) inside the distributor or a bad connection.
Some really good info about Code P0320 here from another forum: https://www.fullsizebronco.com/posts/7250676/
Sadly miesk5 is no longer with us.
Old Jun 8, 2025 | 12:56 PM
Bruce51's Avatar
Bruce51
My 1997 460 OBD 2 Ca. truck has a bronze gear on the distributor. Chances are yours may be the same. The bronze gear is a bear to get off. I did mine but only due to the low mileage.
Getting the oil pump shaft aligned is quite a task as well.
I hope this info helps.
Bruce
Old Jun 9, 2025 | 06:37 AM
tomatogrower
I ordered a new Wai Global distributor from Rockauto... I was hoping for a Motorcraft branded... noticed a grease lube is recommended on the gearing prior to installation... found my Craftsman timing light from the 80's... appreciate the responses...
Old Jun 9, 2025 | 11:00 PM
manicmechanic007's Avatar
manicmechanic007
You are on your way
Great, you have a timing light
Use it
Good luck
Have fun with it
obsxl
24
Nov 10, 2024 05:30 PM
Epicduck
Feb 3, 2018 12:50 PM
Kyle Campbell
Feb 11, 2016 12:42 PM
7.5GasHog
Jun 19, 2014 05:30 PM
scouterspokane
Sep 7, 2005 11:01 AM
